Latest post Wed, May 20 2020 8:50 PM by Job ter Burg. 2 replies.
  • Wed, May 20 2020 4:31 PM
    • JakeZZ
    • Joined on Tue, May 31 2011
    • Posts 3
    • Points 45
    monitor Question
    Why does the source side of my monitor look lighter than the record side(on the right)?
    Shouldn't they look exactly the same?
  • Wed, May 20 2020 7:19 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,744
    • Points 47,975
      Moderator: MCA Mac
    Re: monitor Question
    JakeZZ,
    First, we need a bit more information. What version of MC are you using and on what platform? If you look at the bottom of this post, you can see the spec's for the systems I use (you can add this in your profile). What is the source material (e.g. H.264, DNxHD, etc.) and what is the project format? Also, did you import the material or link the material?
    To add your system spec's, click on your user ID (named to the Welcome, upper right) and choose Edit My Profile. Select the Profile Options tab and you can fill in the blanks as desired.
    Dave S.
  • Wed, May 20 2020 8:50 PM In reply to
    Depends on how the display color space for each is set. Right-click each window.
