Latest post Wed, Jul 8 2020 5:33 PM by Job ter Burg. 9 replies.
Page 1 of 1 (10 items)
  • Fri, May 22 2020 5:38 PM
    • bartekJ
    • Joined on Mon, May 30 2011
    • Wroclaw, Polnad
    • Posts 12
    • Points 135
    OpenIO_NDI vs DX Nitris
    Hello,
    I have a case that I want to stream using Open IO NDI video from Media Composer to someone on my local network in another room.
    But, unfortunately, the option become available only when I turn off my DX Nitrs from the Device Manager.
    While i do it by button HW/SW Enable/Disable there is no NDI option.
    Is there any way to do some ready present in the settings in MC so that the turn off DX does not have to restart the entire computer?
    MC 2020.4
    PC - Z440
    Win 10
    XDCAM HD
    - 10x MC 2018.12.2 HPZ440 Win Pro 7; Xeon E5‐1650v3; 32GB DDR4‐2133; NVIDIA Quadro K2200 4GB - 4x MC 2018.12.2 HPZ4 G4 Win Pro 10; Xeon W-2133 W10P;... [view my complete system specs]
  • Tue, May 26 2020 11:16 AM In reply to
    Re: OpenIO_NDI vs DX Nitris
    As far as I know you can only switch between NDI or Nitris - you can't have them both. If you want to stream to local network to do social distancing because of corona, try to stream using "Open Broadcaster Software" (OBS). You can also install a NDI Plugin in OBS and stream to a NDI-monitor in your LAN. OBS can capture your Avid window or parts of your Avid screen if you like.
    Additionally Avid streams via NDI without re-encoding. This will stress your LAN with high datarates beeing transfered.
    My own setup is HP Z420, 32GB, GTX 1060, Blackmagic Mini Monitor 4K | Latest setup I built for a production firm: AMD Ryzen 3900x, 64GB, Radeon Pro 7100... [view my complete system specs]
  • Tue, May 26 2020 2:59 PM In reply to
    • bartekJ
    • Wroclaw, Polnad
    • Posts 12
    • Points 135
    the problem is that I can't switch ...
    I don't want to have both of them because I read that I can't, the problem is that when I just turn off the nitris, I have the nitris off and nothing more
    NDI options and NDI itself works as soon as I disable Nitris definitively from the Windows Device Manager ...
    but after a complete reboot, which is very bothersome.
    And NDI is very useful for remote live pre-release review ... which is becoming very popular in my company.
    I think I have to report it to support, because unfortunately nobody got interested in my post ...
  • Tue, May 26 2020 5:20 PM In reply to
    With the Nitris DX being EOL, I doubt the drivers have been updated to recognize the Open NDI option. The DX has a specific driver, unlike all other modern Open I/O's.
  • Wed, May 27 2020 7:48 AM In reply to
    • bartekJ
    • Wroclaw, Polnad
    • Posts 12
    • Points 135
    Hello Job ter Burg,
    Thank you for your answer.
    You are indeed right! Thank you very much.
    I checked it on DNxIO, DNxIQ, AJA LHe, AHA LHi and it's OK, I can choose the device.
    Do you think that I should report it to the support team as a future request and they will do something about it, maybe they will add this function to Nitris DX, because I have 6 such Nitris, which are still great!
  • Wed, May 27 2020 8:47 AM In reply to
    bartekJ:
    Again, Nitris DX is End-Of-Life, so I would estimate the chances of its drivers being worked on any longer are close to zero. I don't have any inside information, just an educated guess.
  • Wed, May 27 2020 2:38 PM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 587
    • Points 6,935
    what i can add, is that i don't have to restart my whole computer to disable my mojo DX.
    I'm suprised that you should have to restart whole machine. maybe this can be altered.
    MC 2018.12.2 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-7, Mojo DX, Artist Color, Flanders CM240, GTX... [view my complete system specs]
  • Wed, May 27 2020 2:42 PM In reply to
    I think the OP manages to deactivate it, but as long as the DX is present on the system, the NDI option does not show up.
  • Wed, Jul 8 2020 4:36 AM In reply to
    • Fazz Powell
    • Joined on Sun, Dec 3 2006
    • Naples, FL
    • Posts 414
    • Points 5,635
    Job-I was stalking your post looking for anyone having problems with NitrisDX on W10 and you had answered me on the Facebook AEoFB page. :) I see you mention that NDI option shows up the DX is not present on the system.
    I see on the HW/SW toggle on the top of the timeiine HW/SW-Broadcast IP or HW/SW-Disabled as being my only options. And then in the bottom Client Monitor toggle says "disabled" and I can't activate it. I've seen the NDI option somewhere, but I can't find it now...where would I find that? Device Manager doesn't see it for audio or video. When I go to capture, all MC sees is IE1394, not the Nitris I/O. Just wondering if you had any other insight.
    MC 2020.06 w/Symphony option. NitrisDX, HP Z800 Dual 2.67Ghz, 500GB SSD, 96GB Ram, Nvidia M4000, BCC2019, Sapphire2019, TitlePro5, ProTools 10.5,Terrablock... [view my complete system specs]
  • Wed, Jul 8 2020 5:33 PM In reply to
    I would be suspect of your Host Bus Adapter. Do the lights on the NDX come up green?
