Latest post Wed, Jun 24 2020 8:26 AM by camoscato. 14 replies.
Page 1 of 1 (15 items)
  • Mon, May 25 2020 8:58 PM
    • amidav
    • Joined on Mon, Jun 16 2014
    • Posts 11
    • Points 115
    Bugs and issues with avid 2020.4
    Hi all Avid 2020.4 here are a few bugs that I'm encountered
    1. Trying to batch transcode (with keep original frame rate) files and after a few transcodes I'm receiving this error message. i've changed from UME link to quick time, still did the same thing, opened a project with the same FPS still did it. Picture included.
    Also it linked some files twice once in two different video links.
    2. When i mark a few clips in the bin and try to right click the marks disappear and only one file is marked. the only time that it works is if I keep pressing the shift on my keyboard while I press the right click.
    3. When i try to press on the color box and right click it doesn't give me the color but gives me the right click menu. Only when I press on another line in the bin and then return to the line it gives me the option.
    If you haven't insights about this bugs and how it can be avoided.
  • Tue, May 26 2020 6:16 PM In reply to
    • fsm
    • Joined on Tue, Nov 24 2009
    • Germany
    • Posts 170
    • Points 2,075
    Re: Bugs and issues with avid 2020.4
    hi, same problems here and a lot more;
    your #1 is like https://community.avid.com/forums/t/199518.aspx on the mac forum, looks like a general problem with UME
    #2 same here - my workaround is mark all clips and use the top menu and not the right mouse button - or map the desired command a shortcut on the keyboard problem here now i dont have any keys left :/
    #3 i use clip color - but this only works for 1 clip cause i cant find a command for shortcut on keyboard
    for me other glitches in 2020.04:
    #4 cant import mp3 (!!!!!) i have to link them and consolidate. if i dont consolidate and cut with the linked mp3 during 2-3 hours working i cant set the volume.
    #5 cant link or import a lot of mp4s and movs now. maybe 8from 10 dont work. on my last 2018.10 setup fails 1 or 2 from 10 to import.
    #6 much more render time with some bcc2020 effects
    #7 not usable quick titler - i still use the marquee
    #8 coming from 2018.10 the floating bins are a mess
    #9 nice new mov exporter - but for me CBR export fails - the exported file has often a 30x9 ratio or something - VBR works fine
    MC 2018.12.11 & SYM / BM Monitor4K / Windows 10 prof. 64 bit / i7 3930k / Quadro M4000 [view my complete system specs]
  • Tue, May 26 2020 6:28 PM In reply to
    • amidav
    • Posts 11
    • Points 115
    Thank you for showing me that I'm not the only one that is experiencing these things.
    The floating windows and the way they are disappearing is driving me nuts.
    The mp3 bug i have to see, if that happens that's a major deal breaker for me to go back to the old version which worked fine.
    I hope they are going to treat these bugs.
  • Tue, May 26 2020 9:08 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,744
    • Points 47,975
      Moderator: MCA Mac
    One thing you should do if going from 2018.x is to create a new user profile. Some of the window problems are related to the user profile.
    Dave S.
  • Wed, May 27 2020 5:21 AM In reply to
    amidav:
    These two are known bugs. I saw a post somewhere (sorry that I don't remember if it was here or on Facebook) that they are fixed in the next update, which is supposed to come before the end of May 2020.
  • Wed, May 27 2020 7:43 AM In reply to
    • fsm
    • Germany
    • Posts 170
    • Points 2,075
    for #2 & #3 select your clips -> strg+right click solved for me the bug
    btw a lot of mp3 i cant consolidate and wont play in avid. console: "] [MP3ContainerHandler] Parsing stopped due to truncated essence file."
  • Wed, May 27 2020 7:19 PM In reply to
    • fsm
    • Germany
    • Posts 170
    • Points 2,075
    Most of these Bugs seems to be fixed in 2020.05
  • Fri, Jun 5 2020 2:55 PM In reply to
    • ramz434
    • Long Island
    • Posts 233
    • Points 2,920
    The "Frames Get Stuck Inside Decoder" bug using UME on some Mp4's is still going on w/ 2020.5. I had trouble with this on a Catalina Mac w/ 2020.4 and am now having trouble with this on a Win 10 PC w/ 2020.5.
    Have to use the Source Browser and switch the Plugin to QT manually. This has worked so far on PC, but did not work on the Mac side.
    - HP Z400/24gb ram/Windows 10/MC2020.5/256gb Samsung SSD/ NVidia GTX 1080 - Macbook Pro/16gb ram/OS 10.15.4/MC2020.4/Intel UHD 630 [view my complete system specs]
  • Fri, Jun 5 2020 3:28 PM In reply to
    ramz434:
    I've had the same experience in 2020.5 on PC. Anyone else?
  • Mon, Jun 8 2020 10:38 AM In reply to
    • fsm
    • Germany
    • Posts 170
    • Points 2,075
    installing 2020.05 right now, i will check.
    but another OUTSTANDING Bug in 2020.04. is that the consolidated stereo mp3 files are mono .
    CANT IMPORT MP3, so i have to link the file and consolidate the music becomes mono. WT§$"§$"
  • Mon, Jun 8 2020 2:42 PM In reply to
    • fsm
    • Germany
    • Posts 170
    • Points 2,075
    Same in 2020.05
    Cant import mp3. i have to link them and consolidate to mediadrive. and then they become mono.
    going back to the latest 2018er version. f%&%$$k
  • Mon, Jun 8 2020 2:52 PM In reply to
    • Posts 11,262
    • Points 231,880
    fsm:
    Same in 2020.05
    going back to the latest 2018er version. f%&%$k
    Hey there... I created a case so support can check this and see why 2020.4 and 2020.5 are having this issue with MP3 and mono.
    Case # 03960610
  • Tue, Jun 9 2020 7:42 AM In reply to
    • fsm
    • Germany
    • Posts 170
    • Points 2,075
    Thanks.
    The linked MP3 File is stereo:
    but audio mixer ignores the volume. you can set the level in the mixer but its still now difference. so you cant mix
    but u can consolidate the file. the consolidate window says 1of 2 but he is ready after 1 track.
    in the end the sound is left and right the same signal.
  • Thu, Jun 11 2020 9:47 PM In reply to
    camoscato:
    ramz434:
    This has been logged as a bug. 'MCCET-3676 "Frames Get Stuck Inside Decoder" bug using UME on some Mp4s.'
  • Wed, Jun 24 2020 8:26 AM In reply to
    camoscato:
    camoscato:
    ramz434:
    I've tested this in 2020.6 on Windows 10 and it is fixed. (I don't have a Mac to see if it's fixed there, too.)
