Latest post Fri, Jun 30 2006 4:16 PM by joebob. 5 replies.
Page 1 of 1 (6 items)
  • Thu, Jun 29 2006 9:24 PM
    • joebob
    • Tallahassee, FL
    • Posts 36
    • Points 580
    Spectramatte with multiple layers please help
    OK, I've got two people, each as separate clips that I want to chroma key and place right next to each other.
    Layer 1 is pure white text effect, layer 2 is talent "A" with spectramatte effect, layer 3 is talent "B" with DIFFERENT spectramatte effect. However, it appears that layer 3 is taking the exact same properties as the effect in layer 2. When I change up Layer 3's effect, I see no change. So my two people are right on top of each other and I can't separate them.
    How do we do multiple layers with spectramatte?
    Thanks.
    HP Workstation xw8200 Dual Xeon 3.4ghz 2 gigs Ram Windows XP SP2 Nvidia Quadro FX 1400 v 6.12.10.6722 [view my complete system specs]
  • Fri, Jun 30 2006 8:34 AM In reply to
    Re: Spectramatte with multiple layers please help
    I've had to do something similar a while back and I've exprienced the same "buggy" behaviour in Spectramatte.
    I don't know if this helps - I had the "main background" (imported PSD layer) on V1 with talent A on V2, Spectramatte applied.  My second background on V3 (QT movie imported from After Effcts), talent B on V4 with Spectramatte, and then both V3 and V4 collapsed into one track and corner pinned with 3D warp to a "plasma monitor" on my main background layer on V1.  The keying properties, including position, were different for Talent A and B.  Only Talent A would not budge from it's default centered position no matter what I did in the postion properties in SpcMtte.  My workaround was to mixdown the layers I had to corner pin as well as the main backgorund layer into one clip, and then apply talent A with it's spectramatte effect to that.  Not ideal, but it worked.
    Avid Media Composer 2018.10 HP ZBook 17 Gen3, i7-6700HQ CPU @ 2.60Ghz Win 10, 64GB RAM [view my complete system specs]
  • Fri, Jun 30 2006 1:42 PM In reply to
    • joebob
    • Tallahassee, FL
    • Posts 36
    • Points 580
    "Not ideal" is right. Am I to understand that Avid does not permit mutilple layers of spectramatte without performing a video mixdown? That seems silly.
  • Fri, Jun 30 2006 1:47 PM In reply to
    That's the only way I could get mine to work.  I might be wrong.  Maybe someone else has a better solution
  • Fri, Jun 30 2006 3:56 PM In reply to
    • gobucks
    • Toledo, OH
    • Posts 160
    • Points 1,810
    Sounds like some deep nesting techniques to me personally.  Always fun compositing complex elements.
    X64 Windows 7 systems, MC5.X, MOJO, multiple systems. 8540W EliteBook Q820/1800M/8GB/W7X64/MC5 [view my complete system specs]
  • Fri, Jun 30 2006 4:16 PM In reply to
    • joebob
    • Tallahassee, FL
    • Posts 36
    • Points 580
    Ok, well I just upgraaded from 2.2.7 to 2.5.1 and they seemed to fix it, because it works just fine now.
