Latest post Wed, Jul 8 2020 5:28 PM by Job ter Burg. 3 replies.
  • Wed, Jul 1 2020 4:29 PM
    Audio Clip Levels Wrong on Rendered Audio Clips
    Anyone else seeing this?
    On 2020.5 and 2020.6 I am experiencing a problematic issue with clip levels and rendered audio clips.
    For instance, I add a piece of sound to a sequence, adjust the CLIP level to -20dB, add an EQ effect to take off the low end (50Hz slider all the way down).
    As long as the EQ is not rendered, all is fine, but as soon as you render the EQ effect, it appears that the clip level is applied twice, and the resulting playback level is -40dB in stead of -20.
    This does not happen on 2020.4, but does happen on 2020.5 and 2020.6.
    This also happens with AudioSuite effects.
    This is quite an issue, as it is impossible to revise older projects, as a rerender of any audio effects will completely change the mix.
    MC 2020.5 and 2020.6, Win 10 Prof, z840 dual E5-2640v4, 64GB RAM, ISIS media storage (project is running on a local drive).
    Hope this can be addressed soon, as it is quite a serious bug without any usable workarounds, and a recipe for disaster in specific workflows.
  • Thu, Jul 2 2020 4:46 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,744
    • Points 47,975
      Moderator: MCA Mac
    Re: Audio Clip Levels Wrong on Rendered Audio Clips
    I can reproduce what you're seeing. In 2020.6, I created a new timeline, and dropped a clip onto it. I changed the clip volume and dropped the RT EQ3 effect on it. Sure enough, the clip went silent. After rendering, it still went silent. Then I tried a new timeline, brought up the audio mixer but did NOT change the volume, and dropped the EQ3 effect on to the timeline. The clip also went silent.
    However, when I exitted FX mode back to Edit mode, everything worked. So there's an issue there in the effect mode.
    Dave S.
  • Thu, Jul 2 2020 5:41 PM In reply to
    In 2020.6 this issue only seems to happen on stereo/multichannel clips. On mono clips/tracks, behavior seems normal. A support case has been created.
  • Wed, Jul 8 2020 5:28 PM In reply to
    Escalated and logged as MCCET-3725.
