Latest post Thu, Oct 22 2020 12:07 PM by luca.mg. 5 replies.
Page 1 of 1 (6 items)
  • Sat, Oct 17 2020 6:40 PM
    Avid MediaFiles Naming
    Hello,
    I have some WAV files that I linked to Avid MC 2020 from the audio engineer called BWV_Take1, BWV_Take2.wav and so on and so on. When I consolidate the clips to MXF PCM, the names become "A01.5F8B386A_D054FDCC.MXF" -- obviously if I need to give these to a client, it would be really hard to know that this name is for Take 1. Is there any way I can manually change the metadata of the linked WAV original file, or add some metadata in Avid and then consolidate it and hopefully the name can be a different name like A01.TAKE1_D054" or something like that?
    I realize Avid creates MediaFile names on its own to avoid duplicates, but I wonder if there's any way this can be resolved.
    Thank you,
    Asaf
  • Mon, Oct 19 2020 4:01 PM In reply to
    Re: Avid MediaFiles Naming
    After consolidating open avid console ctrl+6, type renamemediafiles+enter, see results in mxf folder...
    12 PCs HP Z6, 3 laptops Dell, HP Zbook G6, AVID MC 2018.12.x licensed, MC 2020.x trial [view my complete system specs]
  • Mon, Oct 19 2020 6:51 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,746
    • Points 44,940
    AsafBlasberg:
    Hello,
    Thank you,
    Asaf
    Are you handing this material to another Avid?  (Since you are consolidating it seems as if you are).  Why not give them the bin with these clips as well?  It should be keeping the original file names.
    Or maybe I am missing something .....
    Jef
    Jef Huey
  • Mon, Oct 19 2020 6:57 PM In reply to
    I've found that sometimes when I drag the MDB database file to the bin, it uses Avid's file naming instead of the file found in the bin.
    So in the bin:
    TAKE1.WAV
    In Avid MediaFiles folder:
    A01.5FG8(etc).MXF (example)
    then if i take the MDB file and drag it back, sometimes it will use Avid's filename, not the one in the bin. Strange. I will do more investigating. I'm consolidating not to send to another Avid, but to do a backup to a portable HD.
  • Mon, Oct 19 2020 7:23 PM In reply to
    More importantly,
    is there a way to send the client a "bin" or some kind of mapping that shows what the AvidMediaFiles name points to like a self-generated Excel file?
    Example
    in the BIN:
    TAKE1.WAV  -> A1.0409.MXF (Avid MediaFiles name)
    ane so on and so on; is there a way to export a bin from avid where it tells me the associated avid mediafile name?
    Thanks!
  • Thu, Oct 22 2020 12:07 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,737
    • Points 67,310
    Why not exporting the clip from the bin to the backup drive? It will retain its human readable name. Other than that, I'm not in front of a system right now to double check, but if there's a bin column for the mediafile name You can export an ALE file with clip name, Avid mediafile name, and whatever You like, and open it with a spreadsheet.
    Symphony 20.9, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
