Latest post Tue, Dec 6 2005 8:25 PM by digitalfx. 12 replies.
Page 1 of 1 (13 items)
  • Tue, Dec 6 2005 5:35 PM
    • digitalfx
    • Posts 9
    • Points 105
    edl problem
    when we do a speed change in Avid, the edl is translated incorrectly. A speed up of 150% shows up in edl as 33% (slo-mo) in edl...what gives???
  • Tue, Dec 6 2005 6:41 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,380
      Moderator: MCA Mac
    Re: edl problem
    It has always been that way and now, with timewarps, it's worse. EDLs have always loosely translated Motion FX. I have always recreated them by hand in online.
  • Tue, Dec 6 2005 6:43 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,380
      Moderator: MCA Mac
    Re: edl problem
    BTW, The EDL template I've found that translates the FX the closest is the CMX 3600.
  • Tue, Dec 6 2005 7:00 PM In reply to
    • digitalfx
    • Posts 9
    • Points 105
    Re: edl problem
    Thanks for the fast replys...my next question is why hasnt Avid fixed this...this is a huge blunder!!!
  • Tue, Dec 6 2005 7:07 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,380
      Moderator: MCA Mac
    Re: edl problem
    Why? Because EDLs are, in all practicality, a thing of the past. Very few in the industry today actually migrate to a tape-based online system and the market for those that do is so small that it really doesn't justify the R&D dollars.
  • Tue, Dec 6 2005 7:37 PM In reply to
    • digitalfx
    • Posts 9
    • Points 105
    Re: edl problem
    I disagree...we still on-line a good bit of our work. In most cases its not an issue, correct....but why have an edl if it doesnt work!!
  • Tue, Dec 6 2005 7:48 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,380
      Moderator: MCA Mac
    Re: edl problem
    You can disagree if you want but, the fact is, you are in a minority these days. Also, it's not that the EDLs don't work, they do, it's just that the templates have not been rewritten to update technology like Timewarps and their variable speed rates. Just as Edit controllers are no longer updated to keep pace with NLE technology. They are just growing farther and farther apart as EDLs become obsolete. Not an ideal trend for your scenario but there you are.
    What Controller are you using and are the speed changes triggers, nodes or pegs?
  • Tue, Dec 6 2005 8:03 PM In reply to
    • digitalfx
    • Posts 9
    • Points 105
    Re: edl problem
    We are using an Axial 2020....but in this case the edl was sent to the transfer house and unfortunatly the speed ups were transfered incorrectly and we now dont have enough footage to online.
    Yes, this is our mistake for not catching it, but in the heat of battle....
  • Tue, Dec 6 2005 8:11 PM In reply to
    • digitalfx
    • Posts 9
    • Points 105
    Re: edl problem
    btw- nothing complicated in the edl other than 4 edits played at 150%...edl listed these at .33
  • Tue, Dec 6 2005 8:12 PM In reply to
    • cutandmix
    • Posts 203
    • Points 2,460
    Re: edl problem
    There are some known bugs with certain versions of edl manager. I've been caught out in the past, and Avid had fixed the problem, but I wasn't aware of the release.
    I'm not saying that this problem has a fix, but do check your version, and the knowledge base for information.
  • Tue, Dec 6 2005 8:17 PM In reply to
    • digitalfx
    • Posts 9
    • Points 105
    Re: edl problem
    we are ver 2.16...the only real update past that is 2.21 correct?
  • Tue, Dec 6 2005 8:21 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,380
      Moderator: MCA Mac
    Re: edl problem
    I believe that's correct. What EDL Template did you send to the Tape house?
    FWIW, I have had the worst problems with Axial systems.
  • Tue, Dec 6 2005 8:25 PM In reply to
    • digitalfx
    • Posts 9
    • Points 105
    Re: edl problem
    GVG 7.0 ...but we tried all of them and they all output the error
