Latest post Mon, Apr 18 2011 11:00 PM by videosmithlaguna. 3 replies.
  • Thu, Jan 17 2008 6:58 PM
    • john4re
    • Posts 23
    • Points 385
    Installing my New Media Composer and I am getting the following fatal exception errors
    I just bought the Media Composer and I am trying to install it. I get the following error messages. If anyone could help me I would appreciate it. Good Luck in your projects! Thanks John
    Fatal error exception
    2008.01.17.12.11.14
    2008.01.17.12.12.03
    Also, when I try to install my Sonic DVDIT I get the following error message
    Error
    Setup has determined that your configuation does not support any of  the included products.
    I have a NX860XL Gateway Computer with the following confiiguation.  I also have a NVIDIA GE FORCE GO 7300 GS Video Card
    Processor
    (2)Intel #6f6, 2000 MHz
    667MHz external bus
      BIOS
    Phoenix Technologies LTD 72.10 10/27/2006
      Memory
    2048MB physical
    90% free resources
    2 memory slots, 0 free (1024+1024)
      Video
    Graphics Adapter: undefined
    Screen Area/Colors: undefinedxundefined pixels, undefined bits per pixel colors
    Monitor: Default Monitor
    Monitor: SEC 52346
      Drives
    C:\ (NTFS) 70307MB total, 9748MB free
    D:\ (FAT32) 5989MB total, 2873MB free
    E:\ CD-ROM/CD-RW or DVD Drive
      Network and Modem
    Upgrade
    (modem) Motorola Inc Motorola SM56 Data Fax Modem
    (net) Intel Intel PRO/1000 PL Network Connection
    (net) Intel Intel PRO/Wireless 3945ABG Network Connection
    (net) Microsoft Direct Parallel
    (net) Microsoft 1394 Net Adapter
      Operating System
    Upgrade
    Windows XP SP2 (Windows XP 5.1.2600 Service Pack 2)
    Original setup date: 1/20/2007
    DirectX Version: 5.03.2600.2180 (xpsp_sp2_rtm.040803-2158)
    SWAP FILE DISABLED
    File cache managed by Windows
  • Thu, Jan 17 2008 7:11 PM In reply to
    • Paris MkVI
    • Norfolk, VA USA
    • Posts 415
    • Points 5,010
    Re: Installing my New Media Composer and I am getting the following fatal exception errors
    Is this a new installation or an upgrade? If it is an upgrade, was it working before?
    You are probably aware that you are running an uncertified system. But in case you are not -
    Avid is VERY picky about hardware. You can't install it on just any computer. Visit this link on the Avid site to see the specs and qualified systems.
    MCA 2.8.3 on Dell 490 • 4GB Ram • Quadro FX3500 Driver 6.14.10.9185 • Avid rs146 x 2 striped as one • 2 internal 500 GB SATA drives. Edit monitor: Sony... [view my complete system specs]
    A gentle answer turns away wrath, but a harsh word stirs up anger. (Proverbs 15:1 NIV)
  • Fri, Jan 18 2008 9:39 AM In reply to
    • john4re
    • Posts 23
    • Points 385
    This is a new installtion. I was using Avid Express DV on this computer and worked fine.
    I will have to contact Avid
    JOhn
  • Mon, Apr 18 2011 11:00 PM In reply to
    My Composer 5.01 wont start up.  Each time I tried to start it I get Exception:fatalerror msg: assertion failed:false file\\sre\msmb\local volumn c.line 1929.  I took all the the msfob and ffmid files out.  Also trashed the MCstate file.  Rolled back windows and defragged.  This is my home unit and i have not used it for months.  It will start up if I leave my firewire drive off but as soon as I turn it on the error message turns on.  The firewire drive which is  agdrive is working perfectly.  I am getting sick of all these weird problems.  I have the xw8400 1500 card xp pro.  Any suggestions or maybe I should just download 5.5, would that clear it up.
    xw8400 4 gigs ram, fx 1500 composer 6.0 Avid DVD, AVID FX windows 7 [view my complete system specs]
    RS
