Latest post Mon, Mar 17 2008 10:28 PM by jwrl. 1 replies.
Page 1 of 1 (2 items)
  • Mon, Mar 17 2008 2:12 PM
    Easiest way to go 200% to 0% on one clip?
    I was trying to take a clip and make it play 200% to 0% instead of 100% to 0 or straight 200%...is there an easy way to do this?
    Thanks...I couldn't figure out any of the Timewarp effects that had keyframes...
    -chewbacca
  • Mon, Mar 17 2008 10:28 PM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,386
    • Points 97,010
    Re: Easiest way to go 200% to 0% on one clip?
    There's a quick-and-dirty workaround which isn't elegant but you can often get away with as an effect.  First create a double speed mtion effect on the clip that you want to modify.  Edit it in and drop the ramp down to 0% timewarp effect onto it.
    This isn't the nicest way to do this because normal speed will look like half speed.  A better way would be to take advantage of Avid's upgrade offer.  Its timewarp has keyframing.
