Latest post Wed, Mar 19 2008 10:45 PM by jwrl. 5 replies.
Page 1 of 1 (6 items)
  • Wed, Mar 19 2008 11:37 AM
    Help with Import of HD MXF
    I'm trying to learn AVID Express Pro so I can then upgrade my camera kit and start shooting and editing in HD.  I've recently got someone to give me a DVD with some footage from the Panasonic HVX200 on in MXF format so I can play with HD work flow.
    Problem - when I try to import the HD MXF file into a BIN I get a message from AVID - "You can not import this file into a BIN. See the documentation for information about transferring media files"
    I think this means it doesn't see the MXF files as video? Perhaps? The same procedure works OK with standard def AVI files for instance.
    I already asked before if Express Pro was suitable for HD use and was told "yes" - so what am I doing wrong?
  • Wed, Mar 19 2008 12:22 PM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,386
    • Points 97,010
    Re: Help with Import of HD MXF
     Without knowing a lot more about your system it's hard to help.  Go to your user profile and add your system details as comprehensively as you can.
    That said, you certainly can import and use media from the HVX200.  I regularly use the HVX202-EN, a variant, and have absolutely no problems.  My version of Avid is currently 5.8, but I've been doing this without problems since 5.2.
    I know that the Avid knowledge base has instructions.  Check it out.
  • Wed, Mar 19 2008 12:39 PM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,944
    • Points 82,400
    i think section 2 of this tutorial will get you on your way
    Menno
    35+ MC's - 224TB Isis - 2.2 PB Spectra T950 - Interplay - 2 Media Central's - 3 TM's - 2 STP's - 500 TB Isilon - 2 Vantage - MOG SPeedrail... [view my complete system specs]
    Twitter Account
    "If you do what you did you will get what you got!"
    My Keys
  • Wed, Mar 19 2008 12:52 PM In reply to
    Thank you both for replies.
    I will check out those tutorials - I am also (as I type) downloading the latest upgrade 5.8.
    One question though...
    Can I just confirm that AVID 5.8 (latest version) does actually support the DVCPROHD format. This is what I am told the footage I've been given is. Searching the web and AVID sites is confusing as it refers to HD support but later says HDV - which is obviously different.
    The HVX best mode is full HD - "DVCPROHD" - so once I've jumped over these hurdles will I be able to edit in that format?
    Thanks.
  • Wed, Mar 19 2008 1:13 PM In reply to
    • tgacga
    • Greensburg, PA
    • Posts 232
    • Points 2,685
    What about .MXF files that are on a dvd as .MXF files...panasonic gave me a disc that has sample files I was going to test out but upon import the editor just closes.  It gets about half way thru the imoport and poof Avid is gone.  Anyone had this happen?  I believe I am follwing the "rules" correctly but might have some other problem.
    HPxw8200 dual 3.4 xeon 4gb DDR-2 SDRAM 73gb scsi sys drive removeable 160gb ide storage drive removeable 320gb sata storagedrive internal 500gb sata2... [view my complete system specs]
  • Wed, Mar 19 2008 10:45 PM In reply to
    • jwrl
    • Posts 8,386
    • Points 97,010
    Lastindependent:
    jwrl:
    DVCpro HD is the format that the Panasonic 200 series cameras use for HD.
