Latest post Wed, Apr 16 2008 2:57 PM by BLKDOG. 13 replies.
Page 1 of 1 (14 items)
  • Wed, Apr 16 2008 12:36 AM
    • ibeamit
    • Joined on Tue, Apr 15 2008
    • Posts 8
    • Points 100
    Trouble Outputting to HDV Camera - Help
    Can someone help – I just upgraded to media composer software, 2.8.1 for the PC, I am running XP service pack 2, Intel Pentium 4,3.2Ghz, 2 gigs of ram, FX 1100 video card, and all internal storage.  I just bought a Sony, HDR-HC9, HDV video camera, and can connect via firewire and digitize audio and video in SD and HD (1080i/59.94 HDV), but can not output using the digital cut back tool back to the camera.  I can output to the camera in SD, but when in an HDV project the digital cut option is grayed out.  In a SD or 1080i.59.94 (HDCAM) the digital cut tool is not grayed out, but when trying to output in those formats I would have to transcode so that is not an option. Has anyone run into this problem or knows how to output back to my camera please help?
  • Wed, Apr 16 2008 4:18 AM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,380
      Moderator: MCA Mac
    Re: Trouble Outputting to HDV Camera - Help
    you don't use digital cut to write back to an HDV device. Under output, choose Export to>HDV device. This creates a transport stream that can be written to your HDV camera.
  • Wed, Apr 16 2008 2:16 PM In reply to
    • ibeamit
    • Posts 8
    • Points 100
     I just tried to make a tansport stream and got this Exception... any thoughts???
    AVID SYSTEM DUMP - Wed Apr 16 06:02:19 2008
    ________ Memory ________________________________________________________
    numPtrs: 248252
    numHdls: 122594
    totalPtr: 0x0e91dc6c (244440172)
    totalHdl: 0x002257b7 (2250679)
    ________ Current Program Stack _________________________________________
    7C90EB94 0012E2F4 KiFastSystemCallRet+0
    603BB030 0012E304 PSPrintStack+70
    60383F9B 0012E394 DmpDump+9B
    6038440C 0012E64C DmpDumpToFile+35C
    6038BE6D 0012EC04 ExceptionContainer::DoStoredException+FAD
    6038CE18 0012EC6C ExceptionContainer::DoStoredException+1F58
    7C359C97 0012ECB4 _CxxLongjmpUnwind+EA
    7C359629 0012ECE4 _CxxExceptionFilter+1C4
    7C3598AD 0012ED3C _CxxExceptionFilter+448
    7C35994A 0012ED6C _CxxExceptionFilter+4E5
    7C359B9D 0012EDA4 _CxxFrameHandler+26
    7C9037BF 0012EDC8 RtlConvertUlongToLargeInteger+7A
    7C90378B 0012EE78 RtlConvertUlongToLargeInteger+46
    7C90EAFA 26902000 KiUserExceptionDispatcher+E
    10801080 10801080
    ________ System Configuration __________________________________________
    System software: Windows NT Version 5.1 Build 2600 Service Pack 2
    Processor type: Unknown Platform
    Physical Memory: 2046 MBytes; Virtual Memory: 2047 MBytes
    User name: Matt
    Application info: Cecil_PR_R39420
    ________ Processes Currently Running ___________________________________
    ________ WindowList ____________________________________________________
    ________ Binary Modules Loaded _________________________________________
    ________ Device Drivers Loaded _________________________________________
  • Wed, Apr 16 2008 2:19 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,380
      Moderator: MCA Mac
    Not really...is this the error message you got? If not, tell us EXACTLY what happened.
    Also, where are you saving the transport stream, are all of your effects rendered?
  • Wed, Apr 16 2008 2:21 PM In reply to
    • ibeamit
    • Posts 8
    • Points 100
     yes, this is the error i got, everything rendered, saved it to the the C: drive - other thoughts???
  • Wed, Apr 16 2008 2:24 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,380
      Moderator: MCA Mac
    Ok, let's try breaking the sequence into smaller chunks. See if you can get ANY portion of it to export.
  • Wed, Apr 16 2008 2:31 PM In reply to
    • ibeamit
    • Posts 8
    • Points 100
     Here is eactly what i did - went to export to HDV -  choose create New transport Stream - checked Use marks and enabled tracks, hit ok, audio worked fine, then while creating video recived this message
    got Exception: Structured Exception, Exception code: 0x0000005, ExceptionString:ACCESS_Violation, FaultAdress:0x70bc06, MiniDumpFileName:8f00b406-1ed6-4d89-b22d-ce6ed32bdf77.dmp
    and earlier message is the dump file. -
    Does any of that help???
  • Wed, Apr 16 2008 2:33 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,380
      Moderator: MCA Mac
    Have you tried exporting the smaller section? An Access violation error could point to a bad media file.
  • Wed, Apr 16 2008 2:34 PM In reply to
    • ibeamit
    • Posts 8
    • Points 100
     tried a smaller piece and audio worked fine, but when video started got new exception
    Exception: start mpeg encoding failed.
    ????  thanks for working with me
  • Wed, Apr 16 2008 2:37 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,380
      Moderator: MCA Mac
    Right....so, let's try another small section toward the end of the piece...same error?
  • Wed, Apr 16 2008 2:48 PM In reply to
    • ibeamit
    • Posts 8
    • Points 100
     yep same exception - seems like it is getting worse - lol
  • Wed, Apr 16 2008 2:49 PM In reply to
    • ibeamit
    • Posts 8
    • Points 100
     can titles screw transporting up??? - all are rendered.
  • Wed, Apr 16 2008 2:52 PM In reply to
    • ibeamit
    • Posts 8
    • Points 100
     I tried one clip and a message comes up - Export to HDV Device - clip length for export must be at least 30 seconds.
  • Wed, Apr 16 2008 2:57 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,380
      Moderator: MCA Mac
    Ok, so how long is your piece?
    IS all of the footage in your sequence HDV? You might try first doing a video mixdown and see if THAT exports for you.
