Latest post Thu, Sep 2 2010 2:39 PM by Marc Eppler. 15 replies.
  • Wed, May 21 2008 12:07 PM
    • Posts 10,284
    • Points 219,185
    Avid for Liquid Users: Lesson 5 - Simple capture error
     The fifth in a series of tutorials created to assist Avid/Pinnacle Liquid users who are considering migrating to Media Composer.
    It is so easy to overlook this simple piece of information when trying to capture, in the beginning.
    Regards,
    Douglas
    This tutorial can be viewed at "Full-screen" by clicking on the icon on the toolbar
  • Sat, Nov 21 2009 10:48 PM In reply to
    • jita
    • Joined on Wed, Dec 13 2006
    • Posts 111
    • Points 1,585
    Re: Avid for Liquid Users: Lesson 5 - Simple capture error
    I am trying to capture video with the audio into MC from a Panasonic DV Deck. When I go to select the Video and Audio Tracks in the capture tool it tells me that the Audio sample clock must be pulled down in order for the video and audio to be captured at the same time. I clicked on the pulldown tab and it said not supported.
    I am trying to capture 24p video format in NTSC
    Can you help me to see what I might be doing wrong>
    thanks
    OS MS Windows XP Pro32-bit SP3, CPU Intel Core 2 Duo E7600 @ 3.06GHz 36 °C RAM 4.0GB ASUSTeK Gfx SAMSUNG (1440x900@60Hz)NVIDIA Quadro FX 1800 4HD 4TB... [view my complete system specs]
  • Tue, Aug 3 2010 6:45 PM In reply to
    Hi Douglas; I just a week ago installed MC4 (will do MC5 when I get my Win 7 64) and thanks to your tutorials, as well as some others from Avid, I am up and running. I didn't find the transition from LE 7.2 hard. In fact I found the workflow rather similar, except that the buttons are in different places.
    However, in reference to lesson 5 in your tutorials: "Simple capture error", I ran into an other problem which also can be called a simple user error:
    After having hocked up the cam to the PC's 1394 port, I could run the tape nicely and see the video in the record monitor.
    Hoever, when I tried the second time, the Capture Tool stated "No Deck" in the green timeline window! Leaving MC, and launcheing LE, the cam worked ok.
    Back in MC I looked around and found under Settings (Project window) > Deck configuration, there had appeared a second entry: "Firmware on No Port" and a Sony cam name in the ajacent box. I deleted this entry, and the cam worked ok. Where this entry came from I don't know because I was in this setting only once to map my Canon.
    I have a screen-shot of this, but don't know how to upload it to  this thread.
    Hope this helps somone in the future.
    Gerrit.
    MC 7.03; System: Gigabyte MA790X-UD3P w/AMD Phenom II X4 940 cpu 3,0 Ghz, 8 Mb ram, Win 7-64, NVIDIA Quaddro FX 3800 gpu w/2 screens, 2x1Tb, 1x500GB and... [view my complete system specs]
    Gerrit
  • Tue, Aug 3 2010 10:03 PM In reply to
    • Posts 10,284
    • Points 219,185
    Hello Gerrit,
    and welcome to the Avid forums.
    Thank you for posting that information.
    Regards,
    Douglas
  • Wed, Sep 1 2010 12:56 AM In reply to
    I have am trying to capture using firewire directly to my sony laptop from a Sony pd150.
    The software reconizes the camera and allows me to play the video but when i attempt to capture i get the following error:
    You may not capture audio & video together unless the audio sample clock is pulled down.
    The tab for the clock is not active.  Any help would be greatly appreciated
    Marc
  • Wed, Sep 1 2010 1:24 AM In reply to
    • Posts 10,284
    • Points 219,185
    Hello Marc,
    This is something that I have never come across.
    So I have no idea at all what you need to do.
    The posts above this one mention a similar problem and the solution.
    Have you tried that?
    Otherwise keep your fingers crossed..... maybe someone with the answer will post their solution.
    Regards,
    Douglas
  • Wed, Sep 1 2010 1:55 AM In reply to
    Are you trying to capture in a 24p project?
  • Wed, Sep 1 2010 2:46 AM In reply to
    yes i have the resolution set dv 25p
  • Wed, Sep 1 2010 3:19 PM In reply to
    Marc Eppler:
    But you're using a Sony PD-150.  Does that record at 24p?  I can't recall, but I don't think it does.  So, if that's the case, then you're trying to capture non-24p footage into a 24p project type.
  • Wed, Sep 1 2010 4:15 PM In reply to
    i am still recording in sd
  • Wed, Sep 1 2010 5:10 PM In reply to
    Marc Eppler:
    What?
    You're not making a lot of sense.  This is an issue of frame rate.  You shot in either 30i or 25i (depending on where in the world you are) and are trying to capture it into a 24p project.  Audio Sample Clock Pulldown only matters in a 24p project.
    Is there a specific reason why you're trying to capture this stuff into a 24p project?  Can you use a 30i or 25i project?
  • Wed, Sep 1 2010 9:30 PM In reply to
    changing the frame rate to  30I or 23.976  both work.  Can i change  the frame rate in a project that I have already created or do i have to start a new project.   Which of the 2 frame rates is preferable.   Sorry if these questions sound stupid but i am just geting started with avid (previous liquid user
  • Wed, Sep 1 2010 10:12 PM In reply to
    Marc Eppler:
    You'd have to start a new project.
    Marc Eppler:
    That depends on how your footage was shot and how you're using it.  For example, if your footage is all SD 30i then it makes sense (to me) to create a 30i project.  If you footage is 24p, then it makes sense to start a 24p project.  But, as I said earlier, I don't think the PD150 shoots 24p.
  • Wed, Sep 1 2010 10:57 PM In reply to
    Thanks for the help i will use 30I.  Is there any way to change the setting after a project has been created or do i need to start a new project
  • Thu, Sep 2 2010 1:52 AM In reply to
    Marc Eppler:
    Kenton.VanNatten wrote the following post at Wed, Sep 1 2010 5:12 PM:
    Kenton.VanNatten:
    Marc Eppler:
