Latest post Tue, Dec 4 2012 4:43 AM by Igor Ridanovic. 6 replies.
Page 1 of 1 (7 items)
  • Thu, Oct 30 2008 6:41 AM
    Media Composer Export to Avid DS
    Learn how to prepare and export a sequence from Media Composer to Avid DS for finishing. All steps are listed at the end of the short video.
    Igor Ridanovic
    www.HDhead.com
    Filed under: , , , ,
  • Wed, Nov 5 2008 2:27 AM In reply to
    • korzon44
    • Posts 2
    • Points 30
    Re: Media Composer Export to Avid DS
    How to export sequence with media to Avid DS. This is not simply process.
    Avid DS not support embedded media and usually lost links to media from Media Composer.
    Best Regards
    Dariusz Ksionek
    korzon44@wp.pl
  • Wed, Nov 5 2008 4:24 AM In reply to
    • mrmikster
    • Los Angeleez
    • Posts 572
    • Points 6,450
    • Moderator: Avid DS
      Moderator: MetaFuze
    What's so complex about it? Consolidate and move the media to a drive. Create an AFE file in MC. Copy the media to your DS MXF folder and conform the AFE.
    Works for me.
    Michael
    "There are no rules for the brave". Albert Einstein
  • Wed, Nov 5 2008 2:59 PM In reply to
    Thanks for your feedback Dariusz.
    You may be referring to linking to MFX media from Avid DS. This was not  a subjet of the tutorial which focuses on how to export and AFE for Avid DS only.
    Still, linking to MXF files shared between Media Composer and Avid DS is not particularly hard if you follow the steps in the manual.
    Igor Ridanovic
    www.HDhead.com
  • Sun, Nov 9 2008 11:24 PM In reply to
    • Adam Sondej
    • New Zealand
    • Posts 40
    • Points 500
    It would be great if the decompose tool had the ability to NOT add "new" to all the clips
    so that DS source side clip effects applied to all instances of the original MC clip.
    DS 10.5.2, Z800 2.93GHz Hex, Kona 3, Nvidia 4000, 16TB JMR Bluestore/Atto 680, Red Rocket MC 5.5.3 [view my complete system specs]
  • Sat, Dec 1 2012 5:46 PM In reply to
    Hi Igor,
    Quick question; why are you decomposing the duplicated sequence?  Why not just export the AFE from the duplicate sequence.  What is the benefit of decomposing just to delete the decomposed clips?
    Thanks for all your tutorials, they're becoming a big help recently!
    Cheers,
    Andi
    Macbook Pro (Retina, 15-inch, mid 2014) 2.5GHz Core i7 16GB 1600 MHz DDR3 NVIDIA GeForce GT 750M 2048MB MacOS Sierra 10.12.6 MC 2018.9.0 Symphony... [view my complete system specs]
  • Tue, Dec 4 2012 4:43 AM In reply to
    You can export an AFE from the original sequence or the duplicated sequence, but what will happen in DS is that all newly conformed master clips will reflect the original clip length from Media Composer.
    For example, if your master clips in Media Composer reflect the duration of the entire tape, they will conform the same way in DS even though your sequence may only use small sections of this tape. This is suboptimal if you intend to capture media from the bin in DS. You'd end up having to capture far more material than what is visible in the timeline.
    You can always capture from timeline though, even in this case, and capturing from timeline ensures you capture only the used material. My personal preference is capturing from the bin because I have more sorting control that way.
    Igor Ridanovic
    www.HDhead.com
