Latest post Thu, Dec 11 2008 3:04 PM by danpersons. 10 replies.
Page 1 of 1 (11 items)
  • Mon, Dec 8 2008 9:10 PM
    • danpersons
    • Joined on Sun, Sep 2 2007
    • Posts 6
    • Points 90
    Importing Zi6 Files into Xpress Pro
    Hi, all,
    I'm recording video on the Kodak Zi6 camcorder (720p; .mov files) and trying to import it into Avid Xpress Pro. While the video seems to import fine, there's either no audio or a loud squeal. Has anyone encountered this and is there any fix?
    Dan
  • Tue, Dec 9 2008 7:21 AM In reply to
    Re: Importing Zi6 Files into Xpress Pro
    system specs? Software, hardware, drivers (versions). We need that info before we can answer questions like this
    Dell Precision 670, Xeon 3Ghz 3GB Memory 1 x 250 systemdisk, Gb 2x500 Gb datadisks, 4x 1Tb datadisks, Soundblaster Audigy, Quadro FX 1400, MC latest, Mojo... [view my complete system specs]
  • Tue, Dec 9 2008 9:28 PM In reply to
    • danpersons
    • Posts 6
    • Points 90
    Hi, jknikman,
    Here are the specs, best as I can determine:
    • Operating software: XP Pro 5.1
    • Version Avid: Xpress Pro 5.2.3
    • Version Quicktime: 7.5
    • System detailed info,
    •      CPU: Amd Athlon 64x2 Dual Core Processor 3800+
    •      ram: 2GB,
    •      drives: Boot (C:): 111 GB; Data (D:): 465 GB; and currently running LaCie Firewire drive: 500 GB
    • Graphic card info, what brand and type: NVIDIA Quadro FX 540
    • Graphic card driver info: NVIDIA 8.4.2.1
    • Firewire card info (Texas Instruments chipset or something else): Texas Instruments OHCI Compliant 1394 Host Controller; VIA OHCI Copmpliant IEEE 1394 Host Controller; SBP2 Compliant IEEE 1394 Device.
    Hope this helps. Thanks!
    Dan
  • Wed, Dec 10 2008 8:45 AM In reply to
    • Brian Suttie
    • Edinburgh, Scotland
    • Posts 917
    • Points 11,570
    If you open the .mov file in Quicktime player and look at the movie inspector (CTRL +I), what format is the audio (under "format", after the video format) regards Brian
    "We'll fix it in post"
    "This is post"
    "aaaahh"
  • Wed, Dec 10 2008 2:25 PM In reply to
    • danpersons
    • Posts 6
    • Points 90
    Hi, Brian,
    It reads: "AAC, Stereo, 48,000 kHz"
    Dan
  • Wed, Dec 10 2008 5:05 PM In reply to
    • Brian Suttie
    • Posts 917
    • Points 11,570
    That should be fine, I've just tried a QT with AAC audio and it imported fine here.  Can you try rolling your QT back to 7.0 which is the recommended version for 5.2.x?
    see:
    http://tinyurl.com/3xtu4p
    regards
    Brian
    "This is post"
    "aaaahh"
  • Wed, Dec 10 2008 5:57 PM In reply to
    • danpersons
    • Posts 6
    • Points 90
    Hi, Brian,
    Can you provide me with steps for backing out? Earliest version of QT I have is 7.2. Also, I'm running QuickTime Pro, so do I have to be concerned about losing my registration?
    Dan
  • Wed, Dec 10 2008 6:13 PM In reply to
    earlier versions of QT can be found on the apple/support site Pro should not be a problem I think, but do check on the apple site. I think I remember an upgrade of pro in the 7 series of versions.
  • Wed, Dec 10 2008 6:28 PM In reply to
    You can download older Qt versions here.
  • Thu, Dec 11 2008 8:54 AM In reply to
    • Brian Suttie
    • Posts 917
    • Points 11,570
    Your QT Pro details should be fine for all 7.x versions.  Make a note of your regitered name and registration code if you don't already have it to hand, just in case.  Can be found in "Edit" "Preferences" "Register"
    regards
    Brian
    "This is post"
    "aaaahh"
  • Thu, Dec 11 2008 3:04 PM In reply to
    • danpersons
    • Posts 6
    • Points 90
    Brian,
    Thank you. I'm working on a project now, so won't be able to try this for a few days. Will update once I've performed the fixes.
    Dan
