Latest post Mon, Jul 2 2012 6:21 PM by skillet. 16 replies.
  • Sun, Feb 8 2009 1:01 PM
    • Posts 10,282
    • Points 219,150
    Apply an Effect to Many Clips with a Double Mouse-click.
    This one could save you some time when applying the same effect to multiple clips on your timeline.
    Regards,
    Douglas
    The playback screen can be maximised by using the "Full-screen" button in the control bar.
  • Sun, Feb 8 2009 3:35 PM In reply to
    Re: Apply an Effect to Many Clips with a Double Mouse-click.
    If your clips are sequential (as in your example), it would be faster to add a new video track then drop the desired effect onto the Filler above the clips.  If you have say four sequential, then another clip that doesn't require the effect, you could do an Add Edit to split the Filler and the effect will only apply to the Filler sections you want.
    http://community.avid.com/forums/t/68303.aspx
    Your double-click method is a good quick way to put effects onto multiple clips if they are non-sequential.
  • Sun, Feb 8 2009 9:21 PM In reply to
    • Posts 10,282
    • Points 219,150
    Thank you, Kenton.
    That's a valuable piece of knowledge to add to the process.
    I didn't know about it before.
    Regards,
    Douglas
    Edit added:
    I looked at the thread you refer to just now.
    It was just starting when I was making the tutorial.........
    Too bad I hadn't seen it first -  then I could have added more meat to my tutorial Geeked
    Douglas
  • Tue, Apr 14 2009 5:09 PM In reply to
    • jkl
    • Joined on Tue, Oct 23 2007
    • Ireland
    • Posts 104
    • Points 1,300
    There are some effects that cannot go across filler so its also handy for this situation!
    thanks
    Media Composer v7.0.3 with Symphony option. AJA in/out express BCC8.1 on HPz400 workstation with 12gb of RAM, Windows 7 professional 64bit NVIDIA QUADRO... [view my complete system specs]
  • Tue, Apr 14 2009 5:30 PM In reply to
    cluas:
    Can you say specifically which ones?  IIRC, any effect that you can apply to a clip can be applied to Filler.
  • Fri, Jun 19 2009 10:42 AM In reply to
    Kenton.VanNatten:
    Douglas,
    A similar method is to hold down Alt while double-clicking the effect in the Effect Palette. This will span a single effect across the selected sequential clips.
    I'm not experienced enough to tell you why you'd want to span and nest versus adding another video track. Perhaps it's a matter of personal taste, but I imagine there is some rationale as for when to use one method versus the other.
  • Fri, Jun 19 2009 11:28 AM In reply to
    • Posts 10,282
    • Points 219,150
    BobbyMurcerFan:
    why you'd want to.........
    From time to time when I am making a tutorial about something such as the above, I get this feeling.
    OK.... you can do it, but why would anyone want to do it?
    My own thoughts are - it is can be useful to know that the possibility exists - in case you need it one day. Geeked
    Regards,
    Douglas
  • Sat, Jan 2 2010 8:24 PM In reply to
    • gerbow
    • Joined on Wed, Oct 3 2007
    • Wales, UK
    • Posts 132
    • Points 1,730
    "why you'd want to": perhaps if you are adding filters to clips that you'll want tweak individually for some clips as opposed to setting globally? Douglas your tutorials are an invaluable resource and much appreciated by this former Liquid user! I am really getting to enjoy using Media Composer now and having these tutorials just a couple of clicks away is making the transition smoother.
    gerbow
    Apple Mac Pro 5,1 2.8GHz Nvidia Ati 5770 graphics card, 1TB system drive; 3 media drives set as raid 0. Mac OS 10.7.3 Black Magic Design Intensity Pro... [view my complete system specs]
  • Sat, Jan 2 2010 10:31 PM In reply to
    BobbyMurcerFan:
    Essentially it is a matter of personal choice, but I like to keep a timeline as uncluttered as possible, so I tend to build multi-layer effects and then collapse them into a single layer. This is also the best way to get clean, global transitions from multi-layers to a single clip, or vice versa. An example of Alt double-click spanning and nesting would be creating a series of images with transitions and then framing those images inside a PIP that floats through the screen.
  • Sun, Jan 3 2010 9:06 AM In reply to
    • Jayanta
    • Joined on Fri, Jul 6 2007
    • India
    • Posts 1,504
    • Points 16,255
    drbgaijin:
    BobbyMurcerFan:
    Regards,
    Douglas
    Yes I second Douglas.
    All Sorts of System as I am a freelance Editor [view my complete system specs]
    "Out of mud the lovely Lotus Blooms, Out of Strife something higher vies "
  • Sun, Jan 3 2010 9:28 PM In reply to
    drbgaijin:
    With this one, lets see? I have a client in later this month with 300 family stills and little money. To save money they have agreed to a standard duration  BUT they really want movement on most of them.
    In script view set standard duration for all the stills (with heads and tails). Select all clips and drag into a timeline
    Create a default Pan and Zoom effect with the 5 or so basic settings that will be the same. (target mode , no eases etc) Works for both Avid and BCC P&Z. Save this effect to a bin.  Lasso the timeline in segement mode and double click on the saved Pan and Zoom effect.
    Result 300 clips with Pan and Zoom effects with my first 5 settings done in less than 5 minutes.    A single click remove effect on the clips you dont want to use it on is still quicker than adding an effect and setting the basics up each time. So why would you not want to have this method in your bag of tricks??
  • Tue, Mar 29 2011 9:40 PM In reply to
    Thanks for your demo on this, Douglas!
  • Tue, Mar 29 2011 9:46 PM In reply to
    • Posts 10,282
    • Points 219,150
    I am glad to have been of help.
    By the way - Welcome to the Avid Community Michale Big Smile
    Regards,
    Douglas
  • Thu, Feb 2 2012 4:06 PM In reply to
    • I'mWorried
    • Joined on Fri, Oct 14 2011
    • Memphis, TN
    • Posts 16
    • Points 150
    Mr. Douglas:
    Thank you so very much for your good works.  I feel like the skies have parted as a result of your tuturials.
    Best,
    William
    MC v8.5.3 on HP Z820 Workstation, 2x Xeon E5-2590v2 2.40 GHz 12 core, RAM 32 GB, Win 7 Pro 64, NVIDIA Quadro K4200 (driver v347.520), HP Turbo G1, Samsung... [view my complete system specs]
  • Wed, Feb 22 2012 4:52 PM In reply to
    • CR8VDO
    • Joined on Mon, Mar 31 2008
    • St. Louis
    • Posts 140
    • Points 1,920
    very helpful, thanks!
    Windows 7 Ultimate (x64) Service Pack 1 (build 7601) Install Language: English (United States) System Locale: English (United States) Installed: 12/13... [view my complete system specs]
