Latest post Fri, Feb 27 2009 1:50 AM by Ervz Tia (Tikboy). 6 replies.
Page 1 of 1 (7 items)
  • Tue, Feb 24 2009 11:10 AM
    Mixed DV & HDV Project
    Hello,
    I apologize, but Please, for the nth time can someone show me the proper way of doing this?
    HERE'S MY PROJECT:
    -We're targeting a SD resolution for DVD/internet/video distribution.
    -Sources are 70% DV (tape) and 30% HDV (tape and m2t files)
    -I started a 30i-NTSC project, tried to import an m2t file.--Of course pictures are stretched.
    How would you do it?
    Thanks.
    Ervz Tia | Video Productions
  • Tue, Feb 24 2009 12:32 PM In reply to
    • Moses.M
    • Joined on Mon, Jun 9 2008
    • Austria
    • Posts 651
    • Points 8,100
    Re: Mixed DV & HDV Project
    tikboy:
    are your DV tapes in 4:3 or 16:9.
    if they are in 16:9 and so is HDV = no problem. just swith to "16:9" and use "proberly sized" to import your m2t files. I'ld edit in HD and do the downscaling in the end.
    if it's 4:3 you've got to decide how your final output should be:
     - 4:3 (with the HDV clips "letterboxed" or "pan & scan"ed) or
     - 16:9 (with your 4:3 footage "zoom"ed or with "sideboxes")
    HP xw8400 - 6GB RAM | W7 64 bit | MC 5.5.2 | Adrenaline with DNxcel Sony Vaio SB1Z1 - 6GB Ram | W7 64 bit | Blackmagic Design Ultra Studio SDI [view my complete system specs]
  • Wed, Feb 25 2009 1:12 AM In reply to
    Thanks.
    DV clips are 4:3.
    I want to preserve as much resolution as possible so I guess I'm looking at a 4:3 ratio.
    But I'm willing to go whatever is the easiest route.
    Any suggestions?
  • Wed, Feb 25 2009 1:17 AM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,305
    • Points 40,020
    Use the Reformat effect on the HDV material.  Decide whether you want that material to be letterbox or Panned and Scaned.
    Read up on the Reformat effect.  It is your friend in this case.
    Good luck.
    Jef
    Jef Huey
  • Wed, Feb 25 2009 2:19 AM In reply to
    Thanks!
    So, should I import the m2t files on it's native format?...i mean do I need to change the project format before importing? Does it matter? Just making sure I'm not loosing a lot.
    In addition, when importing, I noticed that some of the m2t files gives an error but some imports fine.
    Filed under: , , , ,
  • Thu, Feb 26 2009 12:19 AM In reply to
    • jef
    • Maryland
    • Posts 3,305
    • Points 40,020
    I can not help you there - I never have never used that format.
    Jef
    Jef Huey
  • Fri, Feb 27 2009 1:50 AM In reply to
    UPDATE:
    I just noticed that m2t files keeps his resolution even when imported to a DV project. But QT (HD) files can be affected by the import setting.
    Can some one clarify this?
    thanks.
