Latest post Mon, Jul 6 2009 10:01 PM by motoriley. 6 replies.
Page 1 of 1 (7 items)
  • Tue, Apr 14 2009 11:01 AM
    • eikulon
    • Joined on Mon, Feb 5 2007
    • hamburg, germany
    • Posts 6
    • Points 60
    nvidia quadro fx 3800
    hello there!
    does anyone know if there will be an avid certified driver for the nvidia quadro fx 3800 soon?
    MC 3.5.1 / Win XP SP3 / Supermicro X7DWA / Dual Xeon Quadcore @ 2,5 Ghz / Nvidia Quadro FX 3800 / 4 GB Ram / Adaptec Raid 10 Disc Device (136 GB) / Intel... [view my complete system specs]
    the shorter the better
  • Tue, Apr 14 2009 1:38 PM In reply to
    • cuervo
    • Joined on Fri, May 2 2008
    • Santa Fe, NM
    • Posts 1,174
    • Points 15,595
    Re: nvidia quadro fx 3800
    All the quadro cards use the same driver. Therefore, whatever driver is recommended by Avid for your version of MC is the right driver.
    SYS1:ASUS Z97, Haswell 4.0GHz CPU, 32GB RAM, Quadro 4200 + GTX1070, Thunderbolt II -DNxIO-FSI CM171 ///SYS2:ASUS Maximus Extreme V, Sandy Bridge 3.1GHz... [view my complete system specs]
  • Tue, Apr 14 2009 1:52 PM In reply to
    • eikulon
    • hamburg, germany
    • Posts 6
    • Points 60
    i know this is the usual way. but the driver recommended by avid doesn't support the 3800 :-(
  • Tue, Apr 14 2009 2:17 PM In reply to
    • cuervo
    • Santa Fe, NM
    • Posts 1,174
    • Points 15,595
    The nVidia website shows the driver for the FX3800 here:
    http://www.nvidia.com/object/winxp_182.46.html
    It's the same driver listed for all the Quadro cards. I believe the situation is that there are no earlier drivers for the FX3800 because the card is new to the Quadro line. This being the case, you're in for a LOOOONG wait because Avid will only issue supported video card drivers as nVidia releases them and Avid has the chance to verify them. I would suggest you use the earliest driver that nVidia has released that supports the FX3800.
  • Tue, Apr 14 2009 3:26 PM In reply to
    • eikulon
    • hamburg, germany
    • Posts 6
    • Points 60
    yes - but they did add compatibility for the 3700 to their older 169.47 driver...
  • Mon, Apr 20 2009 6:17 PM In reply to
    • eikulon
    • hamburg, germany
    • Posts 6
    • Points 60
    ... no more suggestions...?
  • Mon, Jul 6 2009 10:01 PM In reply to
    • motoriley
    • Joined on Thu, Sep 27 2007
    • Montreal
    • Posts 21
    • Points 260
    Any news on the 3800 driver?  I'm running a 3800 with 3.5.1 and it seems to work except I get a little glitching in the top of frame using full screen playbeack even with card set to 60 HZ and flip on vertivcal sync on.
    Riley
    Montreal
