Latest post Thu, Apr 30 2009 10:57 PM by BobRusso. 4 replies.
  • Thu, Apr 30 2009 5:22 PM
    720p@23.976 Project & 30i Footage
    We have a project  720p@23.976  with most of the footage shot at that format. The deliverable will be QTs 720p@23.976 but the project requires to mix SD 30i (digibeta) footage into it. Is there a way inside the 720p project to capture the SD footage or have the  Avid to convert the SD footage if captured on a separate SD project?
    Filed under: , , , ,
  • Thu, Apr 30 2009 9:12 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,255
    • Points 27,845
      Moderator: Avid ISIS
      Moderator: Avid NEXIS PRO
    Re: 720p@23.976 Project & 30i Footage
    The SD can be captured in a NTSC 23.976 project. This will remove the 3:2 on the fly so its a true 23.976 clip which might make the footage have a stutter.
    The other option is to use DVFilm Maker to convert the 29.97 to 23.976. This is a very high quality frame rate conversion.
  • Thu, Apr 30 2009 10:01 PM In reply to
    Thanks Bob I'm waiting for the room to become avaliable and give this a shot.
  • Thu, Apr 30 2009 10:09 PM In reply to
    • conleec
    • Los Angeles
    • Posts 1,320
    • Points 17,065
    BobRusso:
    Unless the DigiBeta footage was originally 24p with pulldown added, then capturing it into a 23.976 project WILL cause it to stutter. I think the DVFilm option is the one that's going to work best for you. You'd have to capture the footage into a 30i project, then export QT reference files of each clip and render new 23.976 versions, which you could then re-import into your 23.976 Avid project. It's not nice, but it does work.
    Chris
    MacPro 3.33Ghz 12 Core (Westmere, MacPro 5,1), 48Gb RAM, nVidia GeForce GTX 680, Intensity Pro (Desktop Video 10.4.3), OS X 10.13.6, MC 2018.12 [view my complete system specs]
  • Thu, Apr 30 2009 10:57 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,255
    • Points 27,845
    I agree, unless its recorded with pull-down, it will cause a stutter. This is often acceptable for an offline and only the clips that are used in the edit can have the frame rate changed.
