Latest post Fri, Nov 22 2013 11:57 AM by Vilem. 22 replies.
Page 2 of 2 (23 items) < Previous 1 2
  • Tue, Sep 21 2010 4:18 PM In reply to
    Re: 4 Simple Steps from HD to an SD DVD
    Ok well I will do some test! Our footage is not HDV though, it is full HD from XDCAM. It does get the Long GOP error though and we are using MC5 but maybe not the latest. I will check. Thanks for your help!
    Avid Media Composer 5 Avid Symphony 6 Windows 7 Pro, NVIDIA Quadro FX1800, Asus Xonar D2 Audio. PDW-700 XDCAM Cameras (Mostly shooting HD422 (50... [view my complete system specs]
  • Tue, Sep 21 2010 4:28 PM In reply to
    • Fish
    • Joined on Sat, Oct 15 2005
    • Filet Post, Halifax NS
    • Posts 557
    • Points 6,780
    I often find adding  a submaster to the top layer and rendering that, or even a colour clamp (which I frequently need) is more efficient than a mixdown and easier to modify to material underneath because all you need do is re-render the effects (“red line” )portions of the effect on top..
    The trick with HDV material is when you're exporting to only choose that top layer and ensure your export settings are set for enabled tracks only. Otherwise you'll get the error.
    It's stupid, really. the Avid should ignore the tracks underneath for the export anyway...but it doesn't so just choose the top most layer be it mixdown, submaster or some other effect, and your audio tracks and then export.
    Hope that helps!
    2012 Westmere MacPro 2 x 2.66 GHz 6-Core Intel Xeon) 6 GB 1333 MHz DDR3 ECC ATI Radeon HD 5870 1024 MB As of Jan 2015 - OS X 10.9.5 (13F34) [view my complete system specs]
    AVID man, AVID fan (since 1993 with version 4.5 - before multiple tracks!)...like to solve my own problems and I try not to bother anyone unless I'm really stumped.
  • Tue, Sep 21 2010 9:38 PM In reply to
    Fish:
    Sorry can you explain what you mean as a submaster? Do you mean a video mix down?
  • Tue, Sep 21 2010 10:28 PM In reply to
    • Fish
    • Posts 557
    • Points 6,780
    Sorry....I’m not being clear.
    Create a new layer. On that layer add a SUBMASTER effect clip (under the image group in your effect palette, I think).
    It's a null effect which is to say it doesn't do anything except by rendering it which forces elements under it (both nested and in the layers below it) to mixdown but (!) with the benefit of you being able to make changes underneath the clip in the lower layers and then simply render the effect again. You can tell if something changed because a “red line” will appear over the area that changed letting you know it needs rendering.
    As for GOP media you have to remember to only select that top layer for export or you’ll get an error saying it can't export GOP media (again, kinda dumb..because it can--it just forces you to take a step yourself)
    Does that help?
  • Wed, Sep 22 2010 6:13 AM In reply to
    • hartfilms
    • Joined on Wed, Nov 16 2005
    • Los Angeles
    • Posts 118
    • Points 1,270
    I have the same workflow as you, Fish. I am thinking Avid stops export if there is any GOP media at all because part of the QT export process is the rendering of unrendered sections of the timeline. Just a thought.
    HP Z440 - Win 7 Pro / MC 8.6.5; Mac Pro (Early 2008) OS 10.6.8 / FCS 3; ASUS VH222H 21.5" x2 1080P LCD Monitors; Mojo SD (not connected for HD/HDV... [view my complete system specs]
  • Wed, Sep 22 2010 11:43 AM In reply to
    • Fish
    • Posts 557
    • Points 6,780
    My experience is the Avid throws up the error AFTER the render...so if you only select the submaster effect layer there is no issue. It's what I do all the time!  Smile
  • Fri, Nov 22 2013 11:10 AM In reply to
    Hello Douglas
    I've watched your many, fine and "paced" instructionals. Thankyou.
    I'm replying to the above post out of sheer frustration. I have been trying for 2 years, no exageration,
    to burn SD DVD's from HD and SD 16x9 AVID projects. I am currently posting to try and gleen some help from the community.
    I have created a new 25i PAL SD project, opened an HD project bin and sequence. Then tried to export QT ref but keep getting a 4x3 result.
    AVID MC7.0.2        win7       sorenson 8       sonic AVID DVD
    What AM I doing wrong? Any advice that works and I'll marry you. Oh the video link above doesn't work for me either.
    I'm jinxed!!!   Ideally, I'd be looking for an "all boxes checked" workflow guide
    Best regards
    Graham Marsh (Blue belt Karate)
  • Fri, Nov 22 2013 11:57 AM In reply to
    • Vilem
    • Joined on Sat, Apr 10 2010
    • Prague
    • Posts 1,404
    • Points 15,465
    rockjazzfunk:
    The Pal project, the QT reference is always 4:3. This is due to the essence of the resolution (720x576). QT to the container does not have metadata information on the interpretation of pixels and interprets the only square resolution. Set the aspect ratio to 16:9 I set up the calculation of MPG. This means the input QT 4:3 (720x576), the output MPG 16:9 (720x576). I use TMPGmastering or Sorenson.
    V.
    AVID MC2018.12.1 - dongle, HP Z620 - 2 x Intel Xeon E5-2620, Quadro P2000 - driver 390.77, RAM 48GB - DDR3, BM Intensity Pro 4k - 10.11, W10 - 64bit Professional... [view my complete system specs]
