Latest post Mon, Mar 14 2011 10:24 PM by TVPROD. 24 replies.
Page 2 of 2 (25 items) < Previous 1 2
  • Thu, Feb 25 2010 4:27 PM In reply to
    • MASRAT
    • Joined on Thu, Feb 25 2010
    • Posts 6
    • Points 80
    Re: anyone using DX hardware with single quad or dual 2.26GHZ Nehalem?
    Hi BLK
    No, We are installed the HIB card in slot 4 and it is telling that PCI11af,b as card and other multimedia as type and no in driver installed.
    Please advice how to fix this issue.
    System Configuration:2x2.26 Nehalem,640 Gb Sata HDD,10.6.2 snow leopard,AVDI MC 4.0.2.
    Thanks in Advance
    Masrat
  • Thu, Feb 25 2010 4:34 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,380
      Moderator: MCA Mac
    Well, if I am understanding you correctly, and the card is not being seen by the system profiler, there is either a problem with the card or the slot on the MB itself.
    Best thing to do now is to give support a call so that they can figure out the problem and send you replacement hardware if needed.
  • Thu, Feb 25 2010 4:57 PM In reply to
    • MASRAT
    • Posts 6
    • Points 80
    Do we need to install the drivers for this , as it is showing No drivers. Please advice.
  • Thu, Feb 25 2010 5:02 PM In reply to
    • MASRAT
    • Posts 6
    • Points 80
    In the Manual, support for Macintosh, for Mac Pro 2.26 Ghz, Quad core it has mentioned support for software only, is this the actual problem, or any issues with the drivers. please advice.
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,380
      Moderator: MCA Mac
    Not on a Mac. The drivers are installed with the application. What version of the MC are you running?
  • Thu, Feb 25 2010 5:05 PM In reply to
    • MASRAT
    • Posts 6
    • Points 80
  • Thu, Feb 25 2010 5:48 PM In reply to
    • MASRAT
    • Posts 6
    • Points 80
    Mojo DX works only on 32 bit and not on 64 bit
  • Thu, Feb 25 2010 5:52 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,380
      Moderator: MCA Mac
    Ok, what I would try first is, with the card in slot 4, uninstall the Avid software, repair permissions on the CPU, then reninstall the software again. Launch the MC and see if the firmware on the DX updates.
  • Thu, Feb 25 2010 5:53 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,380
      Moderator: MCA Mac
    MASRAT:
    That is correct. The Avid software is only supported in 32 bit mode.
  • Mon, Mar 14 2011 10:24 PM In reply to
    • TVPROD
    • Joined on Tue, Aug 3 2010
    • Paris, France
    • Posts 25
    • Points 405
    I have the "same" problem on my 2.26 Nehalem 8core. The mac don't see the card. What was the solution for you? Our card is well in slot 4, and OSX don't see it. I have read there is problems with "passive card" and new ones are ok. Do we have to change our PCIe card or is this a "mac" problem ?
    Regards,
    William;
    (yes we are in 32bits, with MC 5.0.3.8)
    Avid Media Composer and Symphony on MACS (5.5, 6) with Mojos and Blackmagic cards / Caldigit SAS storage / Resolve for grading [view my complete system specs]
