Latest post Wed, Mar 17 2010 4:20 PM by jaruel37. 7 replies.
  • Sat, Sep 12 2009 7:19 PM
    • makurnato
    • Joined on Sat, Sep 12 2009
    • Posts 32
    • Points 410
    Avid AMA Problem with XDCAM HD: Visual C++ Assertion failed
    Hi there,
    i have a problem with the AMA using a XDCam HD Disc.
    it allways stops while scanning the disc with the following Error message:
    Visual C++ Runtime error
    Assertion Failed:
    Line: 159
    And then something with the AMA Plugin Folder
    Exeption: result
    If I try to import the files directly it works without any problems,
    as well if I mount a XDCAM EX it works perfectly.
    Any Ideas
    thanks
    Mat
    Avid MC Nitris DX; Version 5.0.3.7R; Hp XW 8600 / 8 x 3,2 Ghz / 12 GB Ram / Nvidia Quadro FX 3700 Avid Adrenaline; Version 4.5; Hp XW 8600 / 8 x 3,2 Ghz... [view my complete system specs]
  • Sat, Sep 12 2009 9:14 PM In reply to
    Re: Avid AMA Problem with XDCAM HD: Visual C++ Assertion failed
    Not using AMA but when I get that error with importing I find that importing the proxies first often fools the XDCAM into importing the full res HD clips properly.
  • Sun, Sep 13 2009 11:53 AM In reply to
    • makurnato
    • Posts 32
    • Points 410
    importing works allways fine,.... either the proxies or ther high res files.
    the only thing is, if i insert a Disc in a Sony PDW U1 (latest drivers and firmware installed)
    the MC starts scanning the disc and the locators, but it allways stops between 40% and 70%
    with the "Visual C++ error message"
    mat
  • Sun, Sep 13 2009 11:57 AM In reply to
    just a guess
    try installing the latest Microsoft Visual C++ 2005 Service Pack 1
    http://www.microsoft.com/downloads/details.aspx?familyid=766A6AF7-EC73-40FF-B072-9112BAB119C2&displaylang=en
    Social Media Manager at Avid
    Editor-in-Chief avidblogs.com
    Got a great story to tell for #TimelineTuesday?
    Want to share a Media Composer Tutorial on #TutorialThursday?
    Contact me!
    Twitter: @editorbelga
    Facebook: fb.com/editorbelga
  • Mon, Feb 1 2010 11:17 AM In reply to
    • redreini
    • Joined on Thu, Jul 16 2009
    • Germany
    • Posts 21
    • Points 275
    Hi mat,
    how could you solve your problem?
    Got the same error.
    Thankful for any hint.
    Avid Media Composer 3.5.4, Dell Precision Workstation T5500, Win XP Pro SP3, Intel Xeon E5530 @ 2,40 GHz, 4GB RAM,NVidia Quadro FX 1800 Graphics card,Onboard... [view my complete system specs]
    Don´t buy DELL , Nobody can help you, they ignore your problems! Angry
    They are sellers , no support. No
    Build your own systems, then you know what is in there Geeked
  • Mon, Feb 1 2010 12:23 PM In reply to
    • makurnato
    • Posts 32
    • Points 410
    I tried different Versions of Visual C++ from Microsoft,
    and firmwares for the XDCam drive, but nothing really solved the problem.
    for me only the upgrade to MC 4.0 fixed the problem. (it was a 3.5 before)
    sorry, but i wish you good luck and if you find a solution, maybe you
    can post it here
  • Mon, Feb 1 2010 3:34 PM In reply to
    • CreativeControl
    • Joined on Mon, Dec 10 2007
    • Edmonton, Alberta, Canada
    • Posts 410
    • Points 5,190
    I have found that other program installs sometimes replace the C++ library with one that doesn't work for Avid.  I had this happen with AvidDVD.  I think the newest library is not the right library.
    Try taking out all instances of the C++ library.  You could do a repair on the Avid installation but re-installing AvidDVD should put the right one back in.  I think sometimes newer libraries are the problem but I'm not sure in this case.
    2 MC4.0.5 systems, both self built Intel Quad Core PC's. Asus P5n32-e motherboards. One with NV GTX 470 - 275.33 drivers and one with NV 7800GT card... [view my complete system specs]
    Editor/Shooter/Animator - www.creativecontrol.ca
    WWII Aviation Artist - www.actionart.ca
  • Wed, Mar 17 2010 4:20 PM In reply to
    • jaruel37
    • Joined on Wed, Feb 11 2009
    • Posts 3
    • Points 35
    My solution to the problem isn't a real solution, but if you continually hit "Ignore" eventually the AMA clips will show up.
