Latest post Fri, Oct 16 2009 11:16 PM by Serleejus. 6 replies.
Page 1 of 1 (7 items)
  • Tue, Oct 13 2009 12:19 PM
    An Error Has Occured
    Hello,
    I ocassionally get this message when I quit Avid. Any ideas?
    Ervz Tia | Video Productions
  • Tue, Oct 13 2009 5:20 PM In reply to
    • Posts 10,204
    • Points 218,090
    Re: An Error Has Occured
    Something is most likely corrupt.  Can you create a report next time ( select the create report button) and email me when it happens next time?
  • Wed, Oct 14 2009 12:56 AM In reply to
    • Serleejus
    • Posts 364
    • Points 4,715
    Hi, that is the same error I get - the solution is to CLOSE the project first, then QUIT MC. It seems to show up after all the database issues I have been having in this thread.
    http://community.avid.com/forums/p/76012/426112.aspx#426112
    None have been successfully answered.. I have no idea about the database errors / corruption, which has caused this.
    BUT as I have said, if I CLOSE the project first, then QUIT - I do not get that error. Only when I hit option-q or whatever it is on the mac to quit while the projec is open do i get that error.
    uninstalling and re-insatlling completeley did seem to help onle ONCE until I tried to import some files and got that database corruptoin mentioned on my thread did I get that error again.
    Hope you have other ideas?!?!
  • Wed, Oct 14 2009 12:57 AM In reply to
    • Serleejus
    • Posts 364
    • Points 4,715
    Marianna - I will try to create a report, I tried to before but I don't think it actually created one. Which Dir (just incase i missed it) should I be looking for it on the MAC.
    Thanks!
    • Serleejus
    • Posts 364
    • Points 4,715
    Tikboy - a quick question - how or what program did you use to capture that window? it sure beats re-typing all that info.
  • Wed, Oct 14 2009 2:06 AM In reply to
    Thanks everyone.
    I kind of figure that closing the sequence and the bins before quitting helps. It cleared out for a while but it happened again for some reason.
    I'm also wondering if this could be caused by some project assets (stil images) from our local network storage. I used a couple Pan&Zoom effects with sources from our shared storage.
    Serleejus, the screen grab is built-in on Mac. CHEAT SHEET HERE.
  • Fri, Oct 16 2009 11:16 PM In reply to
    • Serleejus
    • Posts 364
    • Points 4,715
    Hi Marianna... here is what it says when I try to create a report
    and it goes back to the menu like the first post. You can only choose EXIT fo FINDER to exit.
    Thank you - Any Ideas?
