Latest post Tue, Nov 24 2009 4:20 PM by Mediaformae. 4 replies.
  • Tue, Nov 24 2009 4:04 PM
    • Mediaformae
    • Joined on Mon, Apr 20 2009
    • Braga, Portugal
    • Posts 5
    • Points 75
    Export quicktime stops at 1/3
    Hello!
    I've searched the forum for hours before I made this post so If I'm posting e recurring issue I apologize.
    I've been trying to export e very small video of 12 minutes using quicktime.
    Strangely at aproximately 1/3 of progress the counter keeps on going, biut the estimated time dissapears along with the estimated time. I tried to push overnight and It was still in 1/3.
    Supposing it would be due to low disk space I've made security copies of other files, both form the boot drive and the media drive to an axternal drive.
    However, the export still reaches only 1/3, whatver the format I export to. DV-PAL, Quicktime Same as Source, Quicktime quarter resolution with several codecs (H.264...), and diminishing bit rates.
    From one day to another I'm simply unable to export.
    The worst is that I got quite a few works already finished in de media drive.
    How do I get out of this one?
    Thanks in advance,
    Miguel
    Mac OS 10.6.8 Media Composer Software 4.0.5 iMac Intel Core 2 Duo 2.16Ghz / 4GB RAM / 250 HDD internal system drive / LaCie 1TB HDD external media drive... [view my complete system specs]
    Miguel Cunha
    Mediaformae
    www.linkedin.com/in/mediaformae
    Filed under: , , ,
  • Tue, Nov 24 2009 4:10 PM In reply to
    Re: Export quicktime stops at 1/3
    MC 3.0 is not supported on 10.5.8 and is not certified to run with QT 7.6. And yes, this is the type of things that tend to get screwed up when you don't stick to approved combinations of MC, OS and QT versions.
    Check the version matrix for details.
    Either backrev the iMac (complicated) or upgrade your MC version to 4.x
  • Tue, Nov 24 2009 4:12 PM In reply to
    Are you really on 3.0?  According to the Version Matrix, you should be on OS 10.5.3 and QT 7.4.5.
    The higher versions of both *could* be your problem.  But if it's worked recently, you might have bad media.
    Try exporting the first 25% and see if that works.  Or the last half.  If it does, it might be a problem with a particular piece of media in your timeline.
  • Tue, Nov 24 2009 4:13 PM In reply to
    Job is a bit faster typist than I am.  :)
  • Tue, Nov 24 2009 4:20 PM In reply to
    • Mediaformae
    • Braga, Portugal
    • Posts 5
    • Points 75
    Thanks Guys.
    I'Ve had no problemas whatsoever in the past, but I'll check the versions and yes it's MC 3. I myself crossed my fingers when I installed it, but it has been working smoothly, for over a year - in fact until 2 days ago.
    I'll also try Kevin's suggestion, since it's onley a 12 minute video due for... yesterday...
    After that I'll comeback to this thread to tell what happened.
    Most welcome
    Miguel
    Miguel Cunha
    Mediaformae
