Latest post Sun, Jan 10 2010 2:07 AM by Marianna. 4 replies.
  • Fri, Jan 8 2010 8:18 AM
    • Posts 10,384
    • Points 220,510
    Tutorial: Creating Place Holders - A Glance
    I have been hearing a lot about Placeholders and Place Holders recently, so I thought I should take a closer look at them.
    I had never really thought about them before.
    I hope that this tutorial will cast some light on the topic.
    Regards,
    Douglas
    This tutorial can be viewed at "Full-screen" by clicking on the icon on the toolbar
  • Fri, Jan 8 2010 10:39 PM In reply to
    • Posts 10,384
    • Points 220,510
    Re: Creating Place Holders - A Glance
    Well, so much for my first "glance" at place holders.
    I received a very interesting email from a friend in New Zealand, who has lots of experience in using place holders. (I have about 1 hour of experience!)
    I will be uploading a second chapter to the Place holder tutorial based on his good advice and suggestions.
    Hopefully it should be online by Sunday............ but who am I to speculate..... hehehehehe
    Regards,
    Douglas
  • Sat, Jan 9 2010 10:48 AM In reply to
    Douglas,
    You are right that Marks Out are inclusive, so if you're in the source monitor and you want to select 1m40, you will need to Mark In, advance 1m39s29 and Mark Out.
    However, if you are in the timeline and you want to use Add Edits every five seconds, you must realise that the Add Edit button is exclusive. So in order to split into 5 second segments, you will need to type +5.00, then Add Edit. In your tutorial, you are dividing the longer clip into 4s29f segments rather than 5s segments. If you were to select to display Clip Durations on the timeline, you would see it displayed there as well.
    Lastly, rather than using ALT-Enter, you may use numerical enter, without ALT, to repeat the previous advancement. Works in Trim Mode as well, by the way.
  • Sat, Jan 9 2010 11:01 AM In reply to
    • Posts 10,384
    • Points 220,510
    Thanks for that feedback, Job
    Very useful information for me and anyone else reading this thread.
    Regards,
    Douglas
  • Sun, Jan 10 2010 2:07 AM In reply to
    • Posts 10,384
    • Points 220,510
    Job ter Burg:
    Douglas,
    Job, I have since edited this Tutorial.
    However your points (which in some cases referred to the original tutorial) are still useful and valid.
    I am posting this explanation in case some viewer who only sees the new version may wonder what you were referring to.
    ? Did that come over correctly ? Huh?
    Regards Douglas
