Latest post Wed, Jan 25 2006 6:33 PM by sep. 14 replies.
Page 1 of 1 (15 items)
  • Sun, Jan 22 2006 10:53 PM
    • sep
    • France
    • Posts 5,593
    • Points 62,620
    handwriting using animatte
    Just curious, is somebody here who made the handwriting FX using animatte ?
    I would like to share tips and tricks about this way to do handwriting FX titles.
    Adrenaline MCA 2.8 XW8400 3Gb RAM DNxcel Board, 760 Gb striped SCSI media storage, 1.2 TB 4 X striped SAS 15 000rpm storage.----MC Soft 2.8 + Mojo HP XW8000... [view my complete system specs]
    sep
     Web site : www.audiacom.com
  • Mon, Jan 23 2006 5:29 AM In reply to
    Re: handwriting using animatte
    Hi Sep,
    You can do it with AniMatte if you want to use the handwriting as a wipe.  If you're talking about just writing on the screen, I'd use the Paint Effect.
    1.  Using the Paint Effect and whatever brush size you want, write the word you want to appear on the screen.
    2.  Select the first keyframe, and set the Path parameter to 0 (nothing drawn).
    3.  Select the last keyframe, and set the Path parameter to 100 (the entire shape/word drawn).
    The system will paint on the effect from the origin point.  Ta-daa!
    adios,
    Carl
    Media Composer 2018.12.2 w/Symphony/SS/PF options, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce... [view my complete system specs]
  • Mon, Jan 23 2006 9:10 AM In reply to
    • sep
    • France
    • Posts 5,593
    • Points 62,620
    Thanks for answer, Carl ! I forgot to say that I would like to do handwriting FX using existing fonts, Brush for example!
    sep
  • Mon, Jan 23 2006 3:12 PM In reply to
    • javierd
    • Posts 28
    • Points 410
    Not sure about using animate, but Boris Red does this rather easily.
  • Mon, Jan 23 2006 3:17 PM In reply to
    It's been a while since I've done it, but it was using a combinationof fonts from the title tool and the paint effect.There's probably good info in the manual, I think that's where I figured it out.
    :: Work - Symphony Nitris DX 3.5.1, HP xw8600 :: Home - Intel 3.0Ghz Quad CPU 8GB G.Skill DDR3 7-7-7 1600 Ram Asus P5E3 Pro NVidia Quadro FX... [view my complete system specs]
    "Don't go by my script, they're always wrong." - producer to me while editing
  • Mon, Jan 23 2006 6:48 PM In reply to
    • sep
    • France
    • Posts 5,593
    • Points 62,620
    javierd
    Yes I know, I look for the easiest way to do it, it seems you're right about Boris, the special feature for handwring is OK, However, when 2 lines are crossing, the mask will become very imprecise. I mean in capital letters, a A for example.or a F. I will look further into Boris !
    Scott
    Where did you see something in the manual about handwriting and animatte or paint FX?
    Thanks for answer
    sep
  • Mon, Jan 23 2006 10:16 PM In reply to
    If I recall I just looked in the manual and read-up on paint and figured it out. I think it may have been a tutorial on the old avidpronet board, this was a long time ago as you can tell :)
  • Mon, Jan 23 2006 10:30 PM In reply to
    • sep
    • France
    • Posts 5,593
    • Points 62,620
    OK, thanks Scott
    sep
  • Mon, Jan 23 2006 10:31 PM In reply to
    I tracked down the spot Iused it on. I've attached a bin with a small sequence that has the write-on effect using paint so you can see how I did it. Change the .txt to.zip on the attachment to open it.
    -edit - I can't attach the file. PM me your e-mail addy and I'll send it to you.
  • Tue, Jan 24 2006 8:38 AM In reply to
    • sep
    • France
    • Posts 5,593
    • Points 62,620
    Many thanks Scott ! This might be VERY helpful !
    No need off private message, my e mail is :
    info@audiacom.com
    sep
  • Tue, Jan 24 2006 6:17 PM In reply to
    • sep
    • France
    • Posts 5,593
    • Points 62,620
    Got your e-mail Scott ! Give a try ASAP.
    Thanks again
    sep
  • Tue, Jan 24 2006 10:27 PM In reply to
    Let me know if it works for you. You will need to customize it of course for what you want but it gives you a starting point.
  • Wed, Jan 25 2006 9:19 AM In reply to
    • sep
    • France
    • Posts 5,593
    • Points 62,620
    Yes, that's what it gives!
    However I can't use it directly, because it' comes from a NTSC project, and I work in PAL
    I've created a new NTSC project and could open it.
    Never mind, thanks again Scott !
    sep
  • Wed, Jan 25 2006 6:13 PM In reply to
    Your welcome, I hope it's helpful.
  • Wed, Jan 25 2006 6:33 PM In reply to
    • sep
    • France
    • Posts 5,593
    • Points 62,620
    Yes, it is !!!!
    sep
