Latest post Fri, Feb 19 2010 4:47 AM by Ssnygg. 4 replies.
  • Fri, Feb 12 2010 3:12 AM
    • Ssnygg
    • Joined on Tue, Apr 11 2006
    • Allentown PA
    • Posts 335
    • Points 4,015
    No more OMF export?
    I'm trying to output OMF so that I can do audio sweetening using older audio software.  But the Composer 4.01 that I'm using doesn't seem to have OMF in the drop down menus for export options.  Was is removed?  I won't get access to my own system for another couple weeks, so I'm stuck with what I have.
    Any ideas?
    I have several systems. 1-Media Composer ver 7 1-Media Composer 8.8.4 1-mac Express 2.2 AB/VB Targa set up The computers I use include: 1-Intel core i7... [view my complete system specs]
    Filed under: , ,
  • Fri, Feb 12 2010 5:38 AM In reply to
    • Hoh
    • Joined on Fri, Dec 23 2005
    • Ohio
    • Posts 202
    • Points 2,415
    Re: No more OMF export?
    If you look under the Export Settings for AAF and highlight the Audio Details tab you can select 'Convert Audio Files to:" and then under the drop down menu you can choose 'project', ' wav (OMF)',  'aif (OMF),' or 'pcm (mxf)'.
    I don't use this feature, but this might be what you are looking for.  Couldn't find much help in help section on this.
    Hope this helps
    -Darin
    (1): Media Composer 2018.12 ∙ Windows 7 Pro ∙ HP Z840 Xeon E5-2620 v3 2.4GHz ∙ 64GB RAM HP Samsung DDR4 2133 ∙ NVIDIA Quadro K4200 385.69 ∙ Matrox Mojito... [view my complete system specs]
  • Fri, Feb 12 2010 5:50 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,582
    • Points 65,470
    There's no OMF export on MXF projects, AAF works the same if You're delivering to ProTools, or try to switch the media creation settings to OMF and see if that works (never tried it myself).
    peace luca
  • Fri, Feb 12 2010 7:31 AM In reply to
    I believe you need to switch to an SD project type, on the Format Tab, in the Project window.
    (wwld)
  • Fri, Feb 19 2010 4:47 AM In reply to
    • Ssnygg
    • Allentown PA
    • Posts 335
    • Points 4,015
    Thanks.  I ended up convincing them to upgrade thier Nuendo so it could accept AAF, but I will look into the other options you provided for future use.
