Latest post Fri, Jun 4 2010 6:11 PM by mjolnarn. 8 replies.
Page 1 of 1 (9 items)
  • Thu, Jun 3 2010 3:53 PM
    • DRW
    • Joined on Wed, Nov 9 2005
    • TORONTO
    • Posts 571
    • Points 6,950
    Select Right= Crash?
    Hi All,
       I  haven't used the Select Righ/Left feature until recently, and when I choose Select Right, modify my selection by deselecting filler, then try and actually move the tracks, I get an error ( range specified for Dup is outside range of component)  and a crash.
       Anyone else notice this?  It suppose it could be a glitch with some corrupt media, but thought I'd check here since everything else works perfectly fine.
    TIA
    =DRW
    iMac, 27", 3.4GHz i5, 24 GB RAM, Radeon Pro 570 [view my complete system specs]
    1-800-IMRENDERING
  • Thu, Jun 3 2010 3:59 PM In reply to
    Re: Select Right= Crash?
    not suere I understand what you are trying to do... select right/remove filler and move TRACKS (to where? or do you mean clips? and what happens if you don't deselect filler?)
    Dell Precision 670, Xeon 3Ghz 3GB Memory 1 x 250 systemdisk, Gb 2x500 Gb datadisks, 4x 1Tb datadisks, Soundblaster Audigy, Quadro FX 1400, MC latest, Mojo... [view my complete system specs]
  • Thu, Jun 3 2010 4:20 PM In reply to
    • DRW
    • TORONTO
    • Posts 571
    • Points 6,950
    Sorry, yes I do mean move clips, but using the Select Right tool it selects all the clips on the entire track, from the scrubber forward.  I am attempting to slide everything up the timeline.
    Same thing happens when I don't deselect filler.
    Just trying to find out if this tool is working correctly for other users, if so it's probably a glitch in my timeline.
    =DRW
    1-800-IMRENDERING
  • Thu, Jun 3 2010 4:30 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,335
    This might be an old bug if you have a filler in the end of the Sequense, not sure if the latest patch will fix it
    Tomas
  • Thu, Jun 3 2010 5:15 PM In reply to
    not at a set at the moment but what happens if you first set in and out points before right selecting?
  • Fri, Jun 4 2010 3:41 PM In reply to
    • DRW
    • TORONTO
    • Posts 571
    • Points 6,950
    Setting ins and outs doesn't seem to change anything, however I have noticed this same crashing behaviour when using segment tool to select several clips and then using the 'trim 1/10 frame' keys to slide them up the timeline.
    So it's not the Select Right tool, but seems to be an issue with the segment tool or a combo of the segment tool and the trim keys.
    Anyone notice anything like this?
    =DRW
    1-800-IMRENDERING
  • Fri, Jun 4 2010 4:42 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    I ask one for time, do you have any fillers in the and of the sequence ?
    Tomas
  • Fri, Jun 4 2010 5:51 PM In reply to
    • DRW
    • TORONTO
    • Posts 571
    • Points 6,950
    No, no filler at the end of the sequence.
    1-800-IMRENDERING
  • Fri, Jun 4 2010 6:11 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    Ok, that would have been my guess, an old known bug, no more ideas..
    Tomas
