Latest post Wed, Sep 15 2010 7:03 PM by davewruck. 18 replies.
Page 1 of 2 (19 items) 1 2 Next >
  • Fri, Jun 11 2010 9:05 PM
    • dor
    • Israel
    • Posts 596
    • Points 7,585
    MC5 and Mojo SDI crashes a lot :-(
    Hi
    Upgrading from a very stale XP SP3 MC4 system to MC5 new WIN7 64 install.
    When working on PAL-DV project with my MOJO SDI for the past 4-5 hours my system has stop responding few times and I had to do hard reset to the computer.
    If adding an AMA folder wit some h H/246 30fps files, I got twice so far  the lovely blue screen..
    For my short test, working for some time with the AMA folder but without my MOJO (wokring in software only mode) was Ok so far..
    MC 2018.4 + MXO2 mini. CPU I7 2600K + 32GB RAM. Nvidia GTX970 driver 388.71. QT.7.7.9 [view my complete system specs]
  • Fri, Jun 11 2010 9:08 PM In reply to
    Re: MC5 and Mojo SDI crashes a lot :-(
    Do you have QT 7.6.6?
    Update your VGA drivers?
    Desktop PC
    Corsair RM750X|Asus P8Z68 Deluxe(Gen3)|i7 2600K@4.4|Corsair 32G DDR3|PNY Quadro P2000(411.95)|Samsung 850 Pro SSD(OS) 256 GB|2x1TB Crucial MX500@RAID 0|2x500GB Mushkin SSD@RAID 0|LG BH16NS40|W10 Pro 64bit|Media Composer Software 2019.6 with Symphony Option on Dongle|2xHP 22'' Monitors|M-Audio AV30 Speakers.
    3 Heads Digital Films
  • Fri, Jun 11 2010 9:41 PM In reply to
    • dor
    • Israel
    • Posts 596
    • Points 7,585
    Hi
    Yes.. QT 7.6.6 and updated driver
  • Fri, Jun 11 2010 9:44 PM In reply to
    What firewire port are you using?
  • Sat, Jun 12 2010 4:58 AM In reply to
    • dor
    • Israel
    • Posts 596
    • Points 7,585
    Hi
    I am using a port from a PCI card (not on board), the same port that I was using with MC4, MC3, MC2.5..
  • Sat, Jun 12 2010 5:13 AM In reply to
    Which card?
  • Sat, Jun 12 2010 6:27 AM In reply to
    • dor
    • Israel
    • Posts 596
    • Points 7,585
    It is a Texas Instruments based card.
    Do you really think this is the problem and a bug in MC?
  • Sat, Jun 12 2010 6:43 AM In reply to
    Around version 3, Avid started to recommend different firewire cards because the old TI based chipsets did not provide enough buffer causing file corruption and instability.
    This is one of the Avid qualified cards.
    Check page 6 of this document for PCI-e firewire cards.
  • Sat, Jun 12 2010 12:45 PM In reply to
    • dor
    • Israel
    • Posts 596
    • Points 7,585
    Hi
    I have a another PCI-E card to try. We'll do it later today.
    My  current PCI card was runiing MC 4.05 without any problems.
    I will also try to do some more tests in software only mode.
  • Sat, Jun 12 2010 7:13 PM In reply to
    • dor
    • Israel
    • Posts 596
    • Points 7,585
    Hi
    I did some more tests today.
    It looks to me the the problem might be in WIN7
    I have moved back to XP SP3 with extactly the same hardware and so far everything is stable!
    Will do some more tests on XP in the next few days
  • Sat, Jun 12 2010 8:10 PM In reply to
    • video652
    • Cincinnati, OH
    • Posts 525
    • Points 6,220
    Your specs don't indicate which windows7 64bit you are using, home premium, professional or ultimate?
    HP Zbook 17 G2. 16gigs of ram, Nvidia k4100m [view my complete system specs]
  • Sat, Jun 12 2010 8:30 PM In reply to
    • dor
    • Israel
    • Posts 596
    • Points 7,585
    Hi
    Yes. I haven't updated my profile yet.
    I have the Windows 7 64bit enterprise
  • Sat, Jun 12 2010 11:10 PM In reply to
    • video652
    • Cincinnati, OH
    • Posts 525
    • Points 6,220
    It could be Windows 7 enterprise 64bit that is causing the problems. Just a thought!
  • Sun, Jun 13 2010 5:06 AM In reply to
    • dor
    • Israel
    • Posts 596
    • Points 7,585
    Hi
    From what I read on the net, the enterprise is the same as the profecional. Just the distribution of the enterprise software is different (to organisations)
    thannks
  • Sun, Jun 13 2010 2:38 PM In reply to
    • dor
    • Israel
    • Posts 596
    • Points 7,585
    So far MC5 MOJO SDI  on my XP SP3 is ok.
    I have just ordered one of the PCI-E card on the list, to be on the safe side..
    Any other users with GOOD expiriance on MC5 / WIN7 64 / MOJO SDI?
