Latest post Mon, Sep 27 2010 7:09 PM by DRW. 4 replies.
  • Fri, Sep 24 2010 4:35 PM
    • DRW
    • Joined on Wed, Nov 9 2005
    • TORONTO
    • Posts 571
    • Points 6,950
    QT Ref = very low audio?
    Hi all,
    I've been capturing and exporting Quicktimes via Quicktime reference, and compressing them for use on our website.  This work flow has been working well, until yesterday.  Suddenly the audio when playing back the Ref file is very very low, almost inaudible, but it is there.
    I am on 4.0.5 Media Composer Adrenaline, QT version 4.6.4.  The project is SD 30i, the media is 3:1.  Export settings are: QT Ref, digital mastering with Mixdown audio turned off.
    When exporting a self contained movie the audio is fine.  When exporting a ref with audio mixed down, the audio is fine. Cannot figure out why the ref file audio is bad.  I have changed systems, users and trashed MC state and Site Attributes files with the same result.
    Any insight would be greatly appreciated.
    TIA
    =DRW
    iMac, 27", 3.4GHz i5, 24 GB RAM, Radeon Pro 570 [view my complete system specs]
    1-800-IMRENDERING
  • Sun, Sep 26 2010 4:03 PM In reply to
    • Jayanta
    • Joined on Fri, Jul 6 2007
    • India
    • Posts 1,504
    • Points 16,255
    Re: QT Ref = very low audio?
    Check your Audio output setting.
    All Sorts of System as I am a freelance Editor [view my complete system specs]
    "Out of mud the lovely Lotus Blooms, Out of Strife something higher vies "
  • Sun, Sep 26 2010 4:11 PM In reply to
    DRW:
    I'm betting that's the reason.
    Try either turning Mixdown audio on (this will create a separate .wav file)
    or try doing an Audio Mixdown of your Sequence and then export with Mixdown Audio unchecked (to prevent the separate .wav from creating)
    If you uncheck Mixdown Audio then you're telling the QTref to reference the original audio media files (which of course would not reflect any of your adjustments.
  • Sun, Sep 26 2010 4:27 PM In reply to
    • Jayanta
    • India
    • Posts 1,504
    • Points 16,255
    Kenton.VanNatten:
    DRW:
    Yes
  • Mon, Sep 27 2010 7:09 PM In reply to
    • DRW
    • TORONTO
    • Posts 571
    • Points 6,950
    Thanks guys,
    I will try your suggestions, however as I mentioned, I have been able to successfully export QT refs in the past with no issues.  This seems to be a new problem.  The workaround for the time being is to in fact export the audio mixdown as an associated .aif file which works but it obviously takes longer and uses more space.
    "which of course would not reflect any of your adjustments."
    For my purposes, this is not an issue.  I am capturing completed master shows and compressing for the web, so there is no need to make any adjustments, as I want to maintain the audio and video at broadcast spec.
    =DRW
    1-800-IMRENDERING
