Latest post Wed, Feb 23 2011 3:31 PM by camoscato. 8 replies.
Page 1 of 1 (9 items)
  • Wed, Feb 23 2011 8:41 AM
    • jiggyjay
    • Joined on Thu, Dec 8 2005
    • UT
    • Posts 127
    • Points 1,780
    Can't trim clips with effects applied??
    Trying to do a photo montage and have the resize effect on pictures.. I'm trying to make the clip longer but MC5 won't let me using smart tool.. Am I not able to make a clip longer or shorter after applying an effect on it? In Liquid I was easily able to do that..
    Windows 7 System- MSI 880 mobo, AMD 1055t X6, 4gb ram, Nvidia GT 240 Hackintosh System- Gigabyte h55 mobo, i5 760, 4 gb ram, Nvidia GT 240 [view my complete system specs]
  • Wed, Feb 23 2011 8:56 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,335
    Re: Can't trim clips with effects applied??
    jiggyjay:
    You cannot make clips longer than they originally are, what was the imported length of your stills and did you create handles into the source viewer before adding them to your sequense ?
    Tomas
  • Wed, Feb 23 2011 10:19 AM In reply to
    • jiggyjay
    • UT
    • Posts 127
    • Points 1,780
    Thanks for the reply.. You're right looks like i'm not able to make them longer than what I originally imported them as.. But it looks like I can't make them shorter either?(looks like you can do that) I guess this is normal in MC?? I have another clip with no effects and dont have any problems reducing the length but can't do it with clips with effects on them.. Also does handles mean an in and out point?
  • Wed, Feb 23 2011 10:37 AM In reply to
    jiggyjay:
    No, not normal.  Can you post a screen shot?  It might help us see what the problem is.
    jiggyjay:
    Handles means material before and after the in and out point.  If you've got a picture that's 30 seconds long and you want to put 10 seconds of it into your sequence, mark in and out around 10 seconds somewhere in the middle, leaving "handles" before and after your in and out points which can be used for making dissolves or trimming longer or shorter.
    ciao,
    Carl
  • Wed, Feb 23 2011 10:38 AM In reply to
    • Posts 10,168
    • Points 217,510
    JJ,
    I tested with 2 tracks.
    Each video track had plenty of heads and tails. (Edit! actually they had one of each.... I meant they had long ones!)
    I added the 3D warp to the top track, resized the picture over time, with a couple of keyframes.
    I could still change the clip length with the effect added.
    I am not sure what effects you are using.
    It is possible that certain effects may not be able to be resized.
    It may also depend on whether you are using fixed or elastic keyframes.
    Actually I tried with both, and I could still lengthen/shorten the clips on the tracks.
    Regards,
    Douglas
  • Wed, Feb 23 2011 11:00 AM In reply to
    • jiggyjay
    • UT
    • Posts 127
    • Points 1,780
    Sorry guys I meant to edit my post.. After posting my 2nd response I tried it again and it works fine when reducing clip lengths and now I know that whenever importing pictures its best to import at a longer time.. Thanks..
  • Wed, Feb 23 2011 1:40 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    I actually have my default import length set to 3600 secs ( = one hour )
    Will not give you larger files into your media library and will always make it sure that your images are enough in length
    Tomas
  • Wed, Feb 23 2011 3:20 PM In reply to
    • Sef
    • Maarssen, The Netherlands
    • Posts 1,008
    • Points 13,650
    What in placing the same picture after the first one? That would make a double length clip?
    And then there is a video mixdown possible for that this part of your TL. Insert that video mixdown and you can add effects to it. And/Or shorten the clip.
    Others may come up with more brilliant ideas.
    MC6.0.5, QT version 7.7.3, AvidFX 6.2(64bit), Squeeze Pro 8.5.0.41, AvidDVD 6.4.4 (still in my system, but I don't use it anymore), Boris Continuum... [view my complete system specs]
  • Wed, Feb 23 2011 3:31 PM In reply to
    Hi Sef,
    Sef:
    As long as you leave handles to make dissolves out of or to trim longer if you need to, there's nothing wrong with just putting the clip in twice.  I'd only do this if I were pressed for time and couldn't just reimport the picture with a longer duration, but that's just me.  :)
    Sef:
    Yes, but the disadvantages of a mixdown are a) you can't batch import it if you have a hard drive problem, b) you can't trim it longer, and c) you can't make a dissolve because a mixdown doesn't have handles.  I'd suggest avoiding a mixdown in this situation.
    ciao,
    Carl
