Latest post Fri, Sep 9 2011 4:33 PM by mtahir. 9 replies.
Page 1 of 1 (10 items)
  • Wed, Jun 1 2011 12:10 PM
    • pdt2
    • Joined on Wed, Jun 1 2011
    • Posts 5
    • Points 75
    Import AVCHD file size limits?
    Importing AVCHD file. Import will begin and almost finish then freezes.  Is there a 2 GB size limit on file size to import?  If so, is there a work around this?
  • Wed, Jun 1 2011 12:43 PM In reply to
    Re: Import AVCHD file size limits?
    pdt2:
    No, there's not.  However, if your AVCHD clips are spanned across multiple files they will not import because Media Composer doesn't support spanned clips.  If you search the forum from the last 30 days for "AVCHD" you'll find a lot of posts about how to import AVCHD clips.
    ciao,
    Carl
    Media Composer 2018.12 w/Symphony/SS/PF options, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce... [view my complete system specs]
  • Wed, Jun 1 2011 1:40 PM In reply to
    • mtahir
    • UK
    • Posts 480
    • Points 5,865
    Do the following:
    1. Get this softare and put it in the directory with your MTS files: FFMBC-0.6-RC3 binary here.
    2. Create a .bat file, put the line below in the file, and put it in the same directory as (1):
    for %%a in ("*.mts") do ffmbc -threads 8 -i "%%a" -vcodec dnxhd -acodec pcm_s16le -flags +ildct -b 120M "%%~na.mov"
    3. Open a CMD window, navigate to the directory in (1) and run the batch file. This will pick-up all your MTS files and convert them to DNxHD120 8-bit with PCM audio, 48KHz, Stereo, 1536kb/s.
    In my case, the MTS files were 1920x1080/50i. The "-b 120M" is the bit rate. The "+ildct" is the interlace flag. Eeach 2GB file (I think it was around 17Mbps), which is around 15m30s, took about 30 minutes to convert to MOV files. FFMBC was processing at around 11-13fps. It's a case of just leaving it running overnight if you have many files. It doesn't take much CPU power to do this.
    With a 2GB MTS file (assuming 1920x1080/50i), the resulting MOV file is around 14GB. On my set-up, it would take about 30 to 50 minutes to import each file into MC5. It would first convert the audio and then a box would appear saying it was doing a fast import.
    I hope that helps.
    Mohammed
    MC2018.1 (Win7) | Dell T7500 with 2 x 6-Core Intel Xeon X5690 3.46GHz CPUs | Triple-Channel 64GB (32GB per CPU) 1333MHz DDR3 EEC FBDIMM | 3GB nVidia Quadro... [view my complete system specs]
    Filed under: , , , , , ,
  • Wed, Sep 7 2011 10:21 AM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,159
    • Points 13,950
    Hi
    On a "old" Intel Core2Quad (Q6700) CPU and Win7/64, I noticed that FFMBC conversion with the above command line is not using all the CPU cores at max. (see the text in the CMD console when FFMBC is launched "Cannot parallelize deblocking type 1, decoding such frames in sequential order"); typically, I get about 11~12 fps conversion rate and 30 % CPU usage in this scenario.
    So I tried to run two CMD processes in parallel, each one running a separate FFMBC conversion (with "-threads 2"). When outputting the encoded result (mov files) to a decently fast disk, I nearly double the total conversion framerate (each conversion process gets about 10 fps, so nearly 20 fps total, and 60% CPU utilization Big Smile ).
    So, to significantly increase your AVCHD conversion rate using FFMBC, don't hesitate to run several instances in parallel (use Windows Task manager and/or Resource Monitor to find what works best for your system) !
    MC 2018.9 (Symphony option)/BCC 10.0.5/RED 5.6; BlackMagic Ultrastudio Mini Monitor (10.11.2.0); DELL Precision 5530 - Intel Core i7-8850H 2.6 GHz - 32... [view my complete system specs]
  • Thu, Sep 8 2011 3:00 PM In reply to
    • bushfilm
    • Baton Rouge, LA
    • Posts 537
    • Points 7,235
    This FFMBC conversion seems pretty tricky and I am not much of a computer whiz. Is there a simpler alternative? I do like the idea of converting to the Avid codec and time is not a big issue. Thanks in advance for your help.
  • Fri, Sep 9 2011 8:45 AM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,159
    • Points 13,950
    mtahir:
    I haven't been able to find the Windows binaries for FFMBC 0.6 or 0.6.1 (http://code.google.com/p/ffmbc/).
    Have you ?
    (I'm still using 0.5, but some fixes in 0.6 seem interesting)
  • Fri, Sep 9 2011 2:59 PM In reply to
    • mtahir
    • UK
    • Posts 480
    • Points 5,865
    Hi BenoitM
    Try this zip file (0.6 version).  I've uploaded it into my Avid user area. Let me know if you can't access the file.
    I primarily used this for spanned mts files. Depending on what camera I'm using, I tend to have smaller mts files which I import directly. I did find recently that using FFMBC (not spanned files) produced some files that wouldn't import into MC5 and I would get an error. I'm not sure what that error was now but direct import into MC5 seemed to work fine. The files that wouldn't import into MC5.0.4 all worked fine in various players.
    Regards
    Mohammed
    PS. I updated the broken link in my original post to point to the file in my Avid user area.
  • Fri, Sep 9 2011 3:16 PM In reply to
    • mtahir
    • UK
    • Posts 480
    • Points 5,865
    bushfilm:
    It's not that tricky... just download the zip file, unzip it into an empty directory, put yout mts files in there too, open a Windows command box (click on Windows Start menu, type cmd in the box), navigate to the directory, and type in the name of the .bat file. This will give you DNxHD120 8-Bit files with PCM audio, 48KHz, Stereo, 1536kb/s. If you run into any issues, you can try posting in the developers forum here. They're very good in responding. We'll try to help as best we can. I don't use it much but it was a bit of a 'get out of jail' card when I needed it. :)
    Regards
    Mohammed
  • Fri, Sep 9 2011 3:39 PM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,159
    • Points 13,950
    mtahir:
    Is is a 0.6 Beta or RC or a full release ?
    Did you compile it yourself ?
  • Fri, Sep 9 2011 4:33 PM In reply to
    • mtahir
    • UK
    • Posts 480
    • Points 5,865
    It's 0.6-rc3 from what I can tell when I call up the exe. I didn't compile it.
