Latest post Mon, Jul 18 2011 7:39 AM by Pat Horridge. 9 replies.
Page 1 of 1 (10 items)
  • Sun, Jul 17 2011 4:57 PM
    • Nnata
    • Joined on Tue, Jul 13 2010
    • Posts 1,026
    • Points 13,665
    Difference between consolidate and decompose?
    I understand that decompose creates new offline media for capture, but are there any other differences between the 2?
  • Sun, Jul 17 2011 5:02 PM In reply to
    Re: Difference between consolidate and decompose?
    Consolidate isn't designed to create offline media.  It is used to move/copy media.  Similar to Decompose, it can move/copy only the segments of clips required to support a sequence.
    (wwld)
  • Sun, Jul 17 2011 6:15 PM In reply to
    The consolidation function is also useful for creating duplicate sets of clips and media that are linked to a different project than the one they were originally created in.
  • Sun, Jul 17 2011 7:01 PM In reply to
    • Nnata
    • Posts 1,026
    • Points 13,665
    So consolidate and decompose are similar in the fact that they both seperate the unused media from a sequence - right?
    Decompose I would use when finishing a tape based offline and preparing for tape capture to hi res media-right?
    I could also use consolidate for an offline to online capture if I don't want the low res media taken offline-right?
  • Sun, Jul 17 2011 7:14 PM In reply to
    Consolidate a sequence: make a dupe of all media that is being used in the sequence (with handles if you want).
    Consolidate master clips: make a dupe of the clip on a new destination drive.
    Consolidate subclips: make a dupe of this part of the media on a new destination drive.
    Decompose a sequence: generate offline clips for all media that is being used in the sequence (with handles if you want).
    You can't decompose master clips.
    Nnata:
    Absolutely. Performing a Batch Capture would sort of have the same result, except Decomposer gives you more control over the batch process (as you can select which clips, etc).
    Nnata:
    I don't get the question. The low res media is not taken offline by itself. If you first consolidate, then delete the media, it would still be offline.
  • Sun, Jul 17 2011 7:50 PM In reply to
    • Nnata
    • Posts 1,026
    • Points 13,665
    Job ter Burg:
    Nnata:
    Nnata:
    Thanks for these great explanations. A lot clearer now. In regards to my last question: What I meant was if I consolidate a low res sequence, I am removing the unwanted media that does not reside in the sequence. So then I would be in a position to select the newly created media (with not unwanted media) and batch capture at a higher res....rather than capture full source tapes.
  • Sun, Jul 17 2011 8:32 PM In reply to
    Nnata:
    Consolidating will not necessarily delete any unused media. And if you do select the option to delete originals, you still may have a lot of unused clips on board (that are completely unreferenced in the sequuence.
    I personally don't consolidate that much anymore, as drive space is so cheap. If you do, I'd recommend consolidating onto an empty drive/partition, then hide/delete/remove the originals on your other media drives.
  • Mon, Jul 18 2011 12:45 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,520
    • Points 64,055
      Moderator: MCA Mac
    Nnata:
    That would be decomposing, not consolidating.
  • Mon, Jul 18 2011 5:56 AM In reply to
    hbrock:
    Nnata:
    Well, you COULD use consolidate, but part of your offline media would be duplicated.
  • Mon, Jul 18 2011 7:39 AM In reply to
    Decompose is useful in that you create a new sequence and new master clips with whatever handles you set.
    You can the decide how to re-capture/re-import those clips rather than with just batch capturing/batch importing the sequence which will just prompt for the required tapes/files.
    Consolidate is normally used to create a new sequence and subset of Avid Media files for media management (so you can blow away the rest) or moving to a different system.
    Take care that not all media can be consolidated (re AMA and "foreign types") This skips those clips that link to media that can't be made into Avid media files and your consolidated sequence will still be linked to the original AMA'd media.
    So with AMA media and a mixture of sources you may need to consolidate and then transcode to get a complete set of media. (I've made a feature request to have this as a single function)
