Latest post Fri, Jul 22 2011 7:44 AM by George Angeludis. 5 replies.
Page 1 of 1 (6 items)
  • Tue, Jul 19 2011 7:53 PM
    • Carneya3
    • Joined on Sat, Nov 13 2010
    • Posts 11
    • Points 135
    Upres DNX36 to DNX-175X from QT Files
    I am about to be handed a project with 35 hours of footage in the form of uncompressed QT files. Shot on PS CAM X35, WEISSCAM HS-2 MKII.  If I ingest it at DNX175X I would be looking at over 2.5 TB of transcoded media. This is too big to fit the transcodes and source files on the same drive.
    I want to ingest at DNX36, and then upres final cut. I have not been able to find a way to do so from QT files. I only know how to do so from tape. I am running avid 5.0.3
    Thank you for your help.
  • Tue, Jul 19 2011 9:17 PM In reply to
    Re: Upres DNX36 to DNX-175X from QT Files
    Well the old way would be to batch import the files in at DNX36.
    When you have your final sequence chose to batch re-import (if the DNX36 media is still online then don't tick the offline media only) Select DNX175 (do you really need the 10bit x?) and let it go.
    Possibly re-render any renders at DNX175 Re-create any titles.
    But possibly AMA to the files and cut then Transcode to DNX175 at the end.
  • Fri, Jul 22 2011 6:05 AM In reply to
    • Carneya3
    • Posts 11
    • Points 135
    If I re-import wont it import the entire file again? Not just the section used? If so, I am back to the original problem of having over 2.5 TB.
  • Fri, Jul 22 2011 7:22 AM In reply to
    Why don't you transcode the final timeline only?
    Desktop PC
    3 Heads Digital Films
  • Fri, Jul 22 2011 7:34 AM In reply to
    • Carneya3
    • Posts 11
    • Points 135
    Thanks for the suggestion. I had actually just tried that minutes before you posted. I suppose my only point of clarification is if I do that, does it actually pull from the source file and transcode a true DNX175X, or is it using the DNX36 in the project and faking a DNX175X.
  • Fri, Jul 22 2011 7:44 AM In reply to
    If it is so then every transcode would be fake.
    Desktop PC
