Latest post Sun, Jul 31 2011 3:19 AM by hbrock. 16 replies.
  • Sat, Jul 30 2011 1:05 AM
    FAILURE TO LAUNCH
    Upgraded to 5.5.2 .  New drive, clean install.  When I try to boot into MC, I get the error message
    can't initialize audio hardware.  This is the crash report:  (forget it, too much information.)
    Any help? I've tried a complete system reboot, and still have the problem.
    My system, although older, is certified: 2.66 Intel Mac Pro, Dual Core, 7 gigs RAM.
    Process:         AvidMediaComposer [149]
    Path:            /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/AvidMediaComposer
    Identifier:      com.avid.mediacomposer
    Version:         5.5.2.18475 (5.5.2)
    Code Type:       X86 (Native)
    Parent Process:  launchd [114]
    Date/Time:       2011-07-29 17:59:55.826 -0700
    OS Version:      Mac OS X 10.6.8 (10K549)
    Report Version:  6
    Interval Since Last Report:          381 sec
    Crashes Since Last Report:           2
    Per-App Interval Since Last Report:  102 sec
    Per-App Crashes Since Last Report:   2
    Anonymous UUID:                      60B18163-5261-4B1C-8CAB-6CF9B8986F9D
    Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
    Exception Codes: KERN_INVALID_ADDRESS at 0x0000000055e5c018
    Crashed Thread:  0  Dispatch queue: com.apple.main-thread
    Thread 0 Crashed:  Dispatch queue: com.apple.main-thread
    0   com.avid.mediacomposer            0x00cf2b92 __tcf_0 + 21
    1   libSystem.B.dylib                 0x9597fbff __cxa_finalize + 208
    2   libSystem.B.dylib                 0x9597fb14 exit + 33
    3   com.avid.mediacomposer            0x000241bd start + 61
    Thread 1:  Dispatch queue: com.apple.libdispatch-manager
    0   libSystem.B.dylib                 0x95987382 kevent + 10
    1   libSystem.B.dylib                 0x95987a9c _dispatch_mgr_invoke + 215
    2   libSystem.B.dylib                 0x95986f59 _dispatch_queue_invoke + 163
    3   libSystem.B.dylib                 0x95986cfe _dispatch_worker_thread2 + 240
    4   libSystem.B.dylib                 0x95986781 _pthread_wqthread + 390
    5   libSystem.B.dylib                 0x959865c6 start_wqthread + 30
    Thread 2:  MTThreadCoreThreads
    0   libSystem.B.dylib                 0x95960b4e semaphore_timedwait_trap + 10
    1   ...ple.CoreServices.CarbonCore    0x98e9e942 MPWaitOnSemaphore + 125
    2   com.avid.AvidCoreThreads          0x041a4d25 Threads::SemaRepNative::Decrement(char*, long long) + 281
    3   com.avid.AvidCoreThreads          0x0419de04 Threads::Sema::Decrement(char*, long long) + 42
    4   com.avid.AvidCore                 0x03c1dafd MTSemaphoreCoreThreads::Decrement(unsigned long, unsigned int) + 255
    5   com.avid.AvidStorageAPI           0x08a9125b StorageAPI::CommandProcessor::Body(StorageAPI::MTThread*) + 61
    6   com.avid.AvidStorageAPI           0x08a93420 StorageAPI::MTThread::Run() + 40
    7   com.avid.AvidCoreThreads          0x041a9ca8 Threads::ThreadImp::StarterFluid(void*) + 344
    8   libSystem.B.dylib                 0x9598e259 _pthread_start + 345
    9   libSystem.B.dylib                 0x9598e0de thread_start + 34
    Thread 3:  MTThreadCoreThreads
    CUT THIS SHORT....way too long.
    How hard is that?
  • Sat, Jul 30 2011 1:09 AM In reply to
    Re: FAILURE TO LAUNCH
    OS 10.6.8 is not yet qualified for any version of MC. You should be running 10.6.6 or 10.6.7. From the Avid Knowledge Base. You also need to running the qualified QT version.
  • Sat, Jul 30 2011 1:50 AM In reply to
    • Pixel Monkey
    • Posts 1,244
    • Points 15,725
    Your OS is too new - have to roll back.
    Don't forget to check the Readme notes on each piece of software you own before you install -- http://dl.avid.com/Files/2238/README_AvidMediaComposer_v5.5.2_Jun_27_11.pdf?id=2238&pid=724
    This isn't just an Avid thing but also applies to any upgrades/installs for other products - from Adobe Photoshop to MS Office.
    ACA Leader__Avid Pro Vid Moderator__Specs? Many. All qualified. But I still do stupid things. :) [view my complete system specs]
    Chris Bove' (Pixel Monkey)
    Twitter: Follow @heybove
    Blog for Craft Editors
    WWLD (What Would Larry Do?)
    WWND (What Would Norman Do?)
  • Sat, Jul 30 2011 1:58 AM In reply to
    Pixel Monkey:
    Good point. Always check system requirements.
  • Sat, Jul 30 2011 2:16 AM In reply to
    ,  my reseller gave me the OS.  Where am I going to get 10.6.6?  Crapola.
    How hard is that?
  • Sat, Jul 30 2011 2:22 AM In reply to
    Scoop up crapola. You can get it here.
  • Sat, Jul 30 2011 12:45 PM In reply to
    10.6.7 will work just fine.
    Reload the OS 10.6 and download this installer.
    http://support.apple.com/kb/DL1361
    MC 2018.9, Blackmagic UltraStudio 4K, 12-Core MacPro, 64 GB RAM, 24 TB Thunderbolt Storage [view my complete system specs]
    Conformity is the jailer of freedom and the enemy of growth. Motion Inc
  • Sun, Jul 31 2011 12:01 AM In reply to
    Ok.  Crapola.  I wiped the drive, and reinstalled 10.6.3, then updated to 10.6.6.  After reinstalling MC, I'm still getting the same error message (only difference, now I'm running .6.6)  Do I really need to update to .6.7?  Can I do that without wiping everything out and starting all over (I like clean installs.)  I've got a client coming over with a project started on 5.5 and I've got to be able to open it.  (Yeah, I know it's a Sunday.)  Any further advice?
    How hard is that?
  • Sun, Jul 31 2011 12:04 AM In reply to
    P.S.  Quicktime 7 is okay right.  The system requirements say they've tested X, but Larry, I think, is suggesting 7 will work fine.
    How hard is that?
  • Sun, Jul 31 2011 12:06 AM In reply to
    It is qualified to run on either 10.6.6 or 10.6.7, but Avid always likes a clean OS Install on Macs. So I would recommend a clean install of 10.6.6, not an update, and reinstall 5.5. Don't forget to deactivate your software license before uninstalling.
  • Sun, Jul 31 2011 12:07 AM In reply to
    • Posts 10,386
    • Points 220,530
    what is really weird is 9 x out of 10 wipeing the drive and installing the right one works.  The only thing 2 things I can think of is.....
    1. do you have ANY hardware attached to the mac at all?  if you do - Mojo, matrox, AJA, remove it.
    2. it is posible the MC app is corrupt and you are installing a bad copy.  can you try and downlaod MC again?
  • Sun, Jul 31 2011 12:10 AM In reply to
    Allow me to clarify:
    Quicktime X is qualified for MC 5.0.x versions and MC 5.5.x versions.
    MC 5.5.2 is qualified for Mac OS 10.6.6 and 10.6.7.
    At this time, NO VERSIONS of Media Composer are qualified for either OS Snow Leopard (10.6.8) or OS Lion X (10.7).
  • Sun, Jul 31 2011 12:37 AM In reply to
    I'm glad Marianna is here.  Larry, thanks for the quick replies.  Let me clarify:  I'm not installing from a download.  I bought the upgrade production package from my friendly reseller (Keycode) a few days ago.  So I'm installing off a disk.  I'm installing the Mac OS off a disk too - Snow Leopard 10.6.3, which I then upgrade via download to 10.6.6 (I suppose I could jump straight to the 10.6.7 update, but if 10.6.6 works...)  so I don't think I need to deactive anything when I reinstall.  Everything acts normally until it hits the "can't initialize audio hardware" bump.  I do have an AJA card installed, and I guess I could remove it - as I've posted elsewhere, I'm able to run MC 3.5.3 off another drive and an older OS, and I've got a PCI e-Sata card - for external drive connectivity - but I'm not pulling that.
    It takes so *** long for the installs, I really don't want to do this again.  Especially as this last try has not produced any results.  If any of this new info helps, fire away.  I'll shut down and pull the AJA card, and try without it, but I'm not going to be happy about that.  I run FCP off the older OS too on the other drive, and I like the card installed for that.
    How hard is that?
  • Sun, Jul 31 2011 1:42 AM In reply to
    WOW!  Okay, It wasn't the AJA card, which I'm going to reinstall in a minute and try to launch again.  It appears to have been nothing more than a Logitech camera/microphone combo (for Skype) attached via USB.  I wasn't thinking about that, but when I saw it in the system pref audio list, I pulled it and tried to launch again, and presto, it worked!  Now, is that a bug?  Does anyone else try to run Skype off the same computer their MC is on?  One of the production houses I work at fairly regularly has their computers set up with Skype, and they run a big set up - off a Unity - with no apparent problems.  (Of course, they probably had professional installers.)
    Anyway, I'm going to keep posting as I ad things back.  Curious.  Perhaps if others can replicate the problem, we can come up with a patch for it.  Now that their working on the ole Magical 64 - we're gonna want to be able to run multiple things (hell, I run multiple apps all the time on 10.5.8 - have FCP open, MC open, Soundtrack Pro open, Squeeze, QT, Compressor - well, probably not ALL of them all the time, nor ALL of them some of the time, but many of them at once, to say nothing about running MPEG Streamclip, and other apps as necessary.  Marianna, thanks for the heads up.
    How hard is that?
  • Sun, Jul 31 2011 1:45 AM In reply to
    P.S.  I wander around different forums - but don't we have some way of noting when a question has been answered/solved?  I can't find any ICON to activate to let Forum users Know this is a thread to which we've sewn up a solution.  (Yeah, yeah, I couldn't resist.)
    How hard is that?
