Latest post Wed, Sep 23 2020 4:12 AM by Buzzkill. 8 replies.
Page 1 of 1 (9 items)
  • Mon, Aug 24 2020 5:21 AM
    • Buzzkill
    • Los Angeles
    • Posts 66
    • Points 930
    Media Composer 2020.6 latency during basic commands
    OS 10.15.4
    Hi all, I just upgraded to MC 2020.6 -- cutting video clips onto an audio sequence (for sync) incurs approximately 3-4 seconds of latency, displaying 2 dialog messages: "Loading file media information" & "Relinking" prior to command completion.
    Also, when adding a marker onto any clip in the source window, Media Composer crashes.
    Should I upgrade to 10.15.6?
    TIA
    MC 2021.2|10.15.7|MacPro 16c|96gb|Pro Vega 2|Kona 5|Pegasus32 R8,R4i|Prism ADA8XR|XDR,LG 24MD4KL,Sony PVM2541 [view my complete system specs]
  • Mon, Aug 24 2020 8:29 PM In reply to
    • Buzzkill
    • Los Angeles
    • Posts 66
    • Points 930
    Re: Media Composer 2020.6 latency during basic commands
    I seem to be having the (above) problems with only Sony A7 footage imported Prores 422, Rec709. All other project footage is Venice, F5 & some A7 all imported slog3, which is functioning correctly.
    Any ideas why cutting with this A7 footage would result in latency & crashing by simply adding a marker?
  • Tue, Aug 25 2020 10:01 AM In reply to
    • morsey
    • Joined on Thu, Dec 12 2019
    • Posts 49
    • Points 595
    I had an issue a few months ago in a MC 2020 project of DNxHD SQ material forcing me to wait with a prompt "Loading media file information" which lasted about 5sec each time I tried to cut a clip into a timeline. I tried many things with Avid Tech support. But in the end they did not have a solution.
    The only solution I could come up with was to import and transcode all my material again. Are you able to do a test to regenerate the material?
  • Tue, Aug 25 2020 12:49 PM In reply to
    • Posts 11,549
    • Points 255,060
    Hey Buzzkill.....
    2020.8 later today and suggest you upgrade as a lot of fixes since 2020.6
    marianna
  • Tue, Aug 25 2020 9:23 PM In reply to
    • Buzzkill
    • Los Angeles
    • Posts 66
    • Points 930
    Thanks morsey - that's exactly what I'm seeing... Just grabbed my source material to reload--I'll give 2020.8 a go then reload if things don't clear up. Appreciate your help!
  • Tue, Aug 25 2020 9:25 PM In reply to
    • Buzzkill
    • Los Angeles
    • Posts 66
    • Points 930
    As always, thank you Ms. Marianna -- hope you're feeling better!
  • Thu, Aug 27 2020 7:40 AM In reply to
    • Buzzkill
    • Los Angeles
    • Posts 66
    • Points 930
    I believe my import settings were incorrect causing the issues cited here. Reloading media with closer attention to import settings & upgrading to 2020.8 seems to have resolved everything.
    However Application Manager states; 'dongle not activated' -- but everything is seemingly functioning...
    Thank you Marianna & morsey!
  • Thu, Aug 27 2020 1:05 PM In reply to
    • Adman
    • Atlanta Georgia, USA
    • Posts 5,432
    • Points 61,720
    • BlogAuthor
      Moderator: Avid Free DV
      Moderator: Avid Xpress DV PC
      Moderator: Avid Xpress Studio
    Thanks for following up. :)
    Mac Pro, 64GB Ram. 1TB SSD system drive, 250Gb SSD external (media) drive. QHD Ultra wide, thunderbolt LG monitor, MC 2019.12.1. Pro Tools 11 HD (Mbox... [view my complete system specs]
  • Wed, Sep 23 2020 4:12 AM In reply to
    • Buzzkill
    • Los Angeles
    • Posts 66
    • Points 930
    • MC 2020.8 • os 10.15.6
    Happening again; creating new sequences or insert/over-write command, experiencing 5 second delays with "Loading Media File Information" & "Relinking" messages displayed, also duplicate master clips generated.
    Occuring across diverse media; Venice, F5, A7s & older archive camera material.
    I'm dead-in-the-water -- any insight much appreciated...
