Latest post Tue, Sep 22 2020 7:28 PM by Buzzkill. 3 replies.
  • Mon, Sep 21 2020 9:57 PM
    • Sam I Am
    • Joined on Tue, May 16 2006
    • Posts 129
    • Points 1,800
    CORE_AUDIOUNDERRUN anybody?
    Hi all,
    I keep getting stopped in my tracks by CORE_AUDIOUNDERRUN messages.
    I'm cutting a feature MC 8.7 on a late 2015 iMac i5 3.2 Ghz with 8GB of DDRL Ram. My media is on a 2TB G-Drive USB 3.0 7200 RPM.
    The project is pretty straight forward. No fancy VFX. Just straight cutting. The MXFs are in DNX36.
    I'm wondering if doubling my RAM will make this problem go away or whether it may be caused by something else. I have two free slots  available.
    Any theories out there?
    Thanks.
    iMac retina 5K, 27-inch, Late 2015 3.2GHz Intel Core i5 24GB 1867MHz DDR3AMD Radeon R9 M390 2048MB [view my complete system specs]
  • Tue, Sep 22 2020 4:18 AM In reply to
    • Buzzkill
    • Los Angeles
    • Posts 66
    • Points 930
    Re: CORE_AUDIOUNDERRUN anybody?
    Lack of Ram is very likely your problem -- try 32gb or more...
    MC 2021.2|10.15.7|MacPro 16c|96gb|Pro Vega 2|Kona 5|Pegasus32 R8,R4i|Prism ADA8XR|XDR,LG 24MD4KL,Sony PVM2541 [view my complete system specs]
  • Tue, Sep 22 2020 3:26 PM In reply to
    • Sam I Am
    • Posts 129
    • Points 1,800
    Thanks for your post Buzzkill.
    If I'm reading the MC specs correctly, 8GB is the minimum requirement. Do you really think 32 GB are needed? I am only using the system for offlining in DNX36.
    I was thinking of adding 2 x 8GB for a total of 24GB.
  • Tue, Sep 22 2020 7:28 PM In reply to
    • Buzzkill
    • Los Angeles
    • Posts 66
    • Points 930
    You should achieve better performance with 24gb. The more Ram, the better Media Composer will perform. 8gb will keep you limited, however you might be able to adjust your PL (play-length) setting to give you some extra margin of help. You can narrow or extend how much of your sequence is 'seen' by Media Composer Ram, therefore a shorter length will utilize less Ram, however @ 8gb's the window is tight. HTH
