Latest post Sat, Jun 19 2021 7:41 PM by luca.mg. 10 replies.
Page 1 of 1 (11 items)
  • Sun, Jun 13 2021 7:14 PM
    • Sims Carter
    • Joined on Thu, May 31 2007
    • Burbank, CA
    • Posts 230
    • Points 3,035
    G-Drive - HFSJ vs NTFS?
    I just bought an external 6TB G-Technology G-Drive USB 3.0 to edit a couple of narrative short films.
    I'm on a PC (Windows 7) and I formatted the drive to NTFS, but it's reading as "HFSJ"?
    Is this okay or will I run into problems down the line?
    And if this is an issue that can't be fixed, what drive would you recommend?
    Thanks!
    Windows 7 Professional 64-bit OEM SP1. Media Composer 7.0.2. Asus P9x79 Pro, Intel Core i7 3820 3.6GHz Quad Core 10MB 130W, 4 x Kingston DDR3-1600 4GB... [view my complete system specs]
  • Mon, Jun 14 2021 12:34 AM In reply to
    Re: G-Drive - HFSJ vs NTFS?
    You probably didn't "clean" the drive before formatting. The head of the drive probably still registers the HFS Journaled partition.
    The only way to fix it is to clean the drive in DiskPart, thus deleting the data.
    https://www.buffalotech.com/knowledge-base/cleaning-a-disk-in-windows-7-using-diskpart
    I highly recommend backing up the drive and cleaning it and formatting it correctly.
    MC 2021.3, W10, MSI X299M, Intel 9940X, Gigabyte 2080Ti Waterforce, 64GB RAM, Samsung 970 EVO M.2 SSD, BM Mini monitor & Dell UP2718Q. MBP 2012 Thunderbolt... [view my complete system specs]
  • Mon, Jun 14 2021 8:51 AM In reply to
    • Sims Carter
    • Burbank, CA
    • Posts 230
    • Points 3,035
    Thank, Dom!  Just tried it and got this error:
    "DiskPart has encountered an error: The I/O operation has been aborted becase of either a threat exit or an application request.
    See the System Event Log for more information."
  • Tue, Jun 15 2021 6:11 PM In reply to
    • Sims Carter
    • Burbank, CA
    • Posts 230
    • Points 3,035
    Any idea where I could troubleshoot this issue? Thanks!
    I can't seem to get past this error.
  • Tue, Jun 15 2021 9:37 PM In reply to
    Try hooking up to a Mac and wiping it on that first.
  • Tue, Jun 15 2021 11:09 PM In reply to
    • DonE
    • Joined on Tue, Aug 18 2009
    • California, USA
    • Posts 136
    • Points 1,640
    The G-Technology web site has a couple of things.
    This one is about the same as Dom's post. Uses diskpart from a cmd prompt to clean the disk.
    https://support-en.g-technology.com/app/answers/detail/a_id/663/related/1
    They also have a Windows Format Wizard download. I have never used this... they call it "New".
    https://support.g-technology.com/downloads.aspx?lang=en
    4x AMC/Sy 20.12- Win10 Pro 64 20H2- i9-9900K 32GB- Radeon RX580- QT779- BMD UltraStudio Monitor 3G DV11.6 ** 1x AMC/Sy 8.6.5-dongle- OSX 10.10.5-Mac... [view my complete system specs]
  • Tue, Jun 15 2021 11:22 PM In reply to
    • Sims Carter
    • Burbank, CA
    • Posts 230
    • Points 3,035
    Thanks, Pat!  Any particular way? (since Mac doesn't have diskpart?)
    There's no option to re-format it as ntfs in disk utility.
    Only mac options or ex-fat, which won't work because the drive is 6tb.
  • Wed, Jun 16 2021 3:46 PM In reply to
    • Sims Carter
    • Burbank, CA
    • Posts 230
    • Points 3,035
    After a loing back & forth, the G-Technology rep suggested that something is wrong with the drive... so I've returned the drive and they're going to replace it.
    So when I get the NEW drive tomorrow...
    What are best pratices to get this to NTFS?
    1. First, cleaning the drive via Diskpart on the PC?
    2. And then formatting the drive afterwards (also on the PC)?
    Correct?
  • Fri, Jun 18 2021 6:49 PM In reply to
    • Sims Carter
    • Burbank, CA
    • Posts 230
    • Points 3,035
    Been chatting with G-Technology for the past two hours to simply reformat this drive as NTFS.
    Diskpart... delete volume... nothing seemed to be working (constant errors) to the point the tech on the chat gave up and said it must be a faulty drive. 2 faulty drives in a row? That's highly unlikely.
    But I tried one last thing and finally got it to work in case anyone else out there is having the same issues:
    Had to first plug it into a Macbook and format it to ExFat using the Disk Utility.
    Then I had to plug it into my PC and in Disk Management, right click on ExFat Partition and hit format to NTFS.
    Not sure why simply formatting a drive to NTFS is such a challenge. haha
  • Fri, Jun 18 2021 7:45 PM In reply to
    Not done it for a while but you used to be able to use the disc untility to mark the drive as unformated or RAW I think.
  • Sat, Jun 19 2021 7:41 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,874
    • Points 69,630
    With external hard disks designed as stupid-proof for the average Mac user, and therefore more difficult to use for the average PC user, I boot from a bootable CD/USB stick running Linux and partition the drive using gparted.
    Symphony 21.3, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
