Hi everyone
I need to playout the film i am working on to a PRoRes file with the 5.1 Mix.
The tracks are
You're doing the export correct, but if your sequence and your mix have been done in stereo, a 5.1 output will be contain a signal on L/R whereas the C/Lfe/Ls/Rs would all be silent. If you need to export an actual 5.1 mix, you need to create an actual 5.1 mix in a 5.1 sequence.
If you have received a 5.1 mix, you need to add it to your sequence as a 5.1 element. That's the best way to go about it.
Great thank you
I ended up creating it in Davinci
but i'll now go and look at the avid settings - yes it was a 5.1 mix i received. I'll have a play in avid this afternoon
THANK YOU
HAPPY NEW YEAR
